Heated Grip Help - Road Glide Forums
post #1 of 5 (permalink) Old 03-19-2011, 09:22 PM Thread Starter
theandyman's Avatar
Question Heated Grip Help
So what am I missing here ? The heated grips should only be functional if the ignition is on , but the diagram shows both the ACC power(5) and the B+ power(3) being connected. So if the switch on the Left(2) is ON the circuit is completed via the B+ even if the ignition is off and no power on the ACC
theandyman is offline
post #2 of 5 (permalink) Old 03-19-2011, 10:12 PM
Send a message via Yahoo to musicman8120
It looks like there should be a relay controlled by the ignition power to allow batt power to flow as long as the relay is energized. Otherwise it appears you'll get power from both sources.
2010 Scarlet Red RGC, ABS, cruise,XM radio,vented lowers, Pro Pipe, SE intake , Thundermax Auto-tune, Arc Audio 6.5's,
Road Zeppelin seat, 16" WindVest, KingTourPak w/ detachable kit, Works Performance Steel Tracker shocks.
PGR member
musicman8120 is offline
post #3 of 5 (permalink) Old 06-04-2011, 02:09 PM
Were you able to get your heated grips completed?
488pipefitter is offline
post #4 of 5 (permalink) Old 06-04-2011, 11:16 PM Thread Starter
theandyman's Avatar
heated grips
I did not fix them I removed them.
There was a short in the wiring, and the grips were always on.
Almost melted the grips , did burn my hands.
The shown circuit still makes no sense to me.
post #5 of 5 (permalink) Old 06-08-2011, 12:50 AM
idahointrudr's Avatar
I noticed mine on a couple of times when I was out in the garage listening to the radio. Gotta remember to shut them off before you switch over to acc.
Kind of strange to say the least. Mine dont work that well. They dont get hot enough and stop working all together sometimes.
I was curious if you knew or found where the short was?
idahointrudr is offline
Iron Aces Rushmore Road Glide Mount w/X-Grip and RAM Finger Grip Bunker Parts for Sale 6 04-06-2017 02:24 PM
HD heated grip instructions? Motormike Controls & Handlebars 0 02-03-2015 08:05 PM
Heated Grip Install!! HELP ME!!! 1BadGlide Do-IT-Yourself 2 05-12-2013 07:58 PM
New bars and Heated Grip questions? Tofast4u Controls & Handlebars 5 01-26-2013 02:19 PM
Heated Grip install. 488pipefitter Aftermarket Accessories 3 06-04-2011 08:01 PM
