hard start - Road Glide Forums
post #1 of 4 (permalink) Old 03-20-2011, 01:24 PM Thread Starter
yarddog's Avatar
hard start
starting after a few miles on the road, stopped for gas went to start bike in gear and engine rotated then locked up, hit start botton again same thing put bike in netural and it started fine. dont know how it didnt shear starter shaft, anybody else have this happen?
yarddog is offline
post #2 of 4 (permalink) Old 03-20-2011, 04:07 PM
allofus81's Avatar
Thats why you shift into neutral?
Never had this issue because I start my bike in neutral ALL the time. That is why they put that little green N on the dash. Its pretty easy shift the transmission down into first gear then stick your toe under the shifter and push up ever so slightly with your toe and the green N will come on.
allofus81 is offline
post #3 of 4 (permalink) Old 03-20-2011, 07:22 PM
hdxbones's Avatar
Sounds like it was just a heat soak hard start, or 'hot restart'. Probably had nothing to do with being in gear.If you were already riding it, the clutch shouldn't of had any residual friction lock. Sometimes you get a 'compression lock' when the bike is hot and you only shut it down for a short period. You can usually prevent it from happening if you 'bump' the starter once, before you actually attempt to start it.
Ridin' Roadglides before they were cool.......
hdxbones is offline
post #4 of 4 (permalink) Old 03-21-2011, 11:50 AM Thread Starter
yarddog's Avatar
compression lock is just how it acted, i might adjust the clutch a red hair.
i always start the bike in gear dont like the big clunk when dropping into first, plus its a hassle to pick my foot and fish around for netural
yarddog is offline
Crank no start, crank start Sam07 Troubleshooting for Road Glides 10 05-15-2018 09:03 AM
How hard is too hard? tlottman *General Road Glide Discussions/Pictures 11 08-28-2015 07:42 AM
SE 255 hard start fixed. Reddobe1 Engine Related 2 07-14-2014 10:29 PM
Hard to start today Deadstroke *General Road Glide Discussions/Pictures 21 02-14-2014 06:43 PM
Occasional Hard start LARGECARTRANSPORT Troubleshooting for Road Glides 4 10-15-2012 06:10 PM
