Any idea's on removing O2 plugs - Road Glide Forums
post #1 of 4 (permalink) Old 03-22-2011, 06:54 PM Thread Starter
Anyone have any idea's other than removal of my pipes to get my O2 plugs out of the head pipes. I put plugs in because I was using a Power Commander. Now I'm going with a Revolution Performance, and I need to get the plugs out. It's looking like I'll have to take the pipes off. What a drag.
RoadGlide0611 is offline
post #2 of 4 (permalink) Old 03-23-2011, 10:18 AM
DED HD's Avatar
What exhaust are you running?
guess its too late if you already plugged them but the Power Commander doesnt require you "plug" the sensors in your exhaust. You can leave the o2 sensors on your exhaust. remove the right hand side cover, locate the stock O2 sensor connections and unplug both connectors.
'10 Red Custom:
DED HD is offline
post #3 of 4 (permalink) Old 03-23-2011, 12:52 PM Thread Starter
I know that now. I plugged them before I knew, now I guess I'LL have to pull the pipes and get some leverage on them.
post #4 of 4 (permalink) Old 03-24-2011, 09:14 AM Thread Starter
Saved myself a lot of work, put a torq socket in the o2 plug, and gave it a good yank, off it came. The other one did the same.
O2 Sensors, bung plugs jchar27 Wanted! (Buy or Trade) 1 09-11-2017 07:58 PM
Removing Trap Door without removing Exhaust kevanbo Do-IT-Yourself 7 04-03-2014 07:01 PM
O2 sensor hole plugs CSM-H Intake and Exhaust 12 07-19-2013 07:48 AM
Found an error code any idea what it means? Dmize Troubleshooting for Road Glides 5 01-15-2013 03:33 PM
Any idea on my ipod jack issue?? PAC MAN *General Road Glide Discussions/Pictures 6 07-13-2011 07:36 AM
