Accessing the battery - Road Glide Forums
post #1 of 1 (permalink) Old 03-26-2011, 07:29 PM Thread Starter
Stray Mutt's Avatar
I went to install the pigtail harness for my Gerbings liner today, and I was a little surprised at the number of layers I had to go through to get to the battery. I couldn't understand how to remove the cover that's immediately above the battery itself. There's an electronic unit that I was able to pop off and a few wiring harnesses that I was able to unplug, but the piece atop the battery didn't seem to come out (and yes, I did unbolt the two hold down capscrews). I managed to get to the battery terminals to connect the harness, but I had to pull back the cover and brace it with one hand while trying to keep from losing the post bolt while loosening - a trick that I somehow pulled off. But I'd be hard pressed to actually remove the battery if I had to. Anyone know of a trick to get to the battery itself? I also understand from cruising other forums that it can be a real challenge to grab and lift the battery.
Stray Mutt is offline
accessing riser bolts THEMASTERDESTROYER Controls & Handlebars 12 01-30-2014 08:40 PM
Battery pte359 Aftermarket Accessories 31 02-21-2012 10:18 AM
Battery Longrider *General Road Glide Discussions/Pictures 9 02-11-2011 09:35 AM
FREE Blackberry 8330 Curve Chargers and NEW Battery HUTMO General Off-Topic Discussions 2 12-31-2010 06:30 PM
Sumax 2 gauge battery cables fleabite *General Road Glide Discussions/Pictures 4 11-22-2010 07:34 PM
