oil cooler - Road Glide Forums
post #1 of 4 (permalink) Old 03-28-2011, 11:39 AM Thread Starter
yarddog's Avatar
oil cooler
going to add a jegg oil cooler to the road glide, what I cant figure out is jegg sells a anti rotation adapter, so the adapter housing dosnt rotate when changing the filter. the filter adapter housing itself can be rotated 1/8 of an inch and touch the engine case where the anti rotation adapter would touch the case
why do I need the anti rotation adapter ??
yarddog is offline
post #2 of 4 (permalink) Old 03-28-2011, 08:51 PM
gazrnr's Avatar
When I did my jagg oil cooler I purchased the anti rotation bracket and did not use it when I did the installation. In short you do not need it.
2009 Road Glide, Fueling 525 Cams, Rinhart Mufflers, SE Air Cleaner, PCV & Autotune, Progressive monotube cartridges, Ohlins shocks
gazrnr is offline
post #3 of 4 (permalink) Old 06-20-2011, 11:22 PM
dirtbag's Avatar
Looking to install a Jagg oil cooler... anyone have one? Have part numbers? Need any accessories with it? I was going to buy the HD oil cooler... but it looks like a no-frills expensive part.
2010 FLTRX - THE RED DRAGON
KCCO - CHIVE ON!
dirtbag is offline
post #4 of 4 (permalink) Old 06-21-2011, 09:34 AM
The HD oil cooler with thermostat is cheaper then the Jagg oil cooler and performs just as well. You should get the oil cooler with the thermostat because the oil will come up to and maintains operating temps, this is important when riding in cooler weather. When you get a Jagg oil cooler you have to buy the thermostat housing separately along with other items, the HD oil cooler comes with everything you need for less money and looks better too.
Oil Bud Oil Cooler easybiker Engine Related 10 07-22-2015 02:34 PM
Oil Bud Oil Cooler install 2013 RG ultra Big_Mo Aftermarket Accessories 0 08-09-2014 10:32 AM
Removing oil filter with oil cooler 02heritage *General Road Glide Discussions/Pictures 17 05-12-2014 12:10 AM
Jagg Oil Cooler turned to Oil Drooler! OldNerdGuy *General Road Glide Discussions/Pictures 6 07-22-2013 12:04 PM
Oil Cooler Tip doc Do-IT-Yourself 8 03-26-2010 03:19 AM
