Wiring a new front brake light switch - Road Glide Forums
post #1 of 5 (permalink) Old 03-29-2011, 08:36 PM Thread Starter
I have to replace that little brake light switch in the throttle side controls. The problem I'm having is that the stock one is wired different than the factory replacement. If you are looking at the switch, the factory one is wired with a red wire with a yellow stripe on the right side and an orange wire with a white stripe on the left side.
On the replacement the wires are reversed. So, do I splice it to match wires, or do I splice it so the right wires follows the factory right wire and the left wire follows the left factory wire?
twr05 is offline
post #2 of 5 (permalink) Old 03-29-2011, 09:51 PM Thread Starter
Here are some pictures. So, I want to splice in the new switch. Hopefully these pictures describe better what I'm asking. Will this switch work regardless of how it is wired, or does it have a positive and negative that need to be wired a specific way?
twr05 is offline
post #3 of 5 (permalink) Old 03-29-2011, 10:31 PM
Howardsternspenis's Avatar
Switch wiring
It's just a switch, it's either gonna be open or closed the color of the wire shouldn't matter.
Howardsternspenis is offline
post #4 of 5 (permalink) Old 03-30-2011, 10:09 AM
prince's Avatar
I agree; the switch just completes the circuit to supply power to the relay, which in turn supplies power to the brake light. Polarity is not an issue.
2005 FLTRI
prince is offline
post #5 of 5 (permalink) Old 03-30-2011, 08:35 PM Thread Starter
Awesome. Thanks
twr05 is offline
No tail light or front brake light hummbusa Troubleshooting for Road Glides 3 06-23-2015 12:00 PM
Front brake light switch bigshaqa Controls & Handlebars 6 06-16-2015 11:57 AM
Front Brake Light Switch Replacement calgaryglide Controls & Handlebars 2 06-19-2012 09:00 PM
Help Removing Rear Brake Light Switch jimmyray11349 Do-IT-Yourself 4 03-17-2012 09:52 PM
Brake light switch (front) firerodder Troubleshooting for Road Glides 4 12-01-2011 06:24 PM
