Dtc u1016 - Road Glide Forums
post #1 of 5 (permalink) Old 03-30-2011, 08:38 PM Thread Starter
Dtc u1016
I have an 11 FLRTX.
I installed new handlebars and farkled up some wiring. I have re-wired everything and replaced parts that I messed up...what a debacle.
My turn signals and brake lights aren't flashing although they are getting power because they do run as running lights. I already replaced the front brake light switch also in case you were wondering.
I have DTC U1016. I read in the sticky that it has to do with the ECM (at least that's the case for the 2010's and I assume it is the same for the 2011's).
Is this something I can fix, or do I need to schedule a trip to the stealership? Please help.
twr05 is offline
post #2 of 5 (permalink) Old 03-30-2011, 08:48 PM Thread Starter
How do I delete this. I accidentally posted this twice
twr05 is offline
post #3 of 5 (permalink) Old 03-31-2011, 01:39 PM
Did you try to clear the code ? If you did clear the code and it keeps coming back you will have to take the bike into the dealer to have the ECM reflashed . The sticky on how to find the DTC's also tells you how to claer the codes . It sound like the TSSM may need to be married back to ECM . The code info is a nice tool but as always there are some things we can fix at home and some things we can't .
post #4 of 5 (permalink) Old 03-31-2011, 03:27 PM Thread Starter
Yea, I've deleted the code and it comes back. Looks like I'm in trouble here. Thanks
twr05 is offline
post #5 of 5 (permalink) Old 04-01-2011, 01:00 PM
These codes could also cause the U1016 code to come up U1040;U1064;U1097;U1255 . The DTC's should be analyzed from the lowest code to the highest code & sense all of these are related to serial data error I would recommend have the dealer look at the bike .
04-07 DTC Codes ironmark Troubleshooting for Road Glides 5 09-01-2015 12:31 AM
Error Code U1016 Loss of ECM Serial Data Q-Hog ECM/Fuel Management systems 6 05-16-2013 12:29 PM
2010 DTC Codes ironmark Troubleshooting for Road Glides 15 06-18-2012 12:41 PM
07-09 DTC Codes ironmark Troubleshooting for Road Glides 2 04-03-2011 12:26 PM
Dtc u1016 twr05 Troubleshooting for Road Glides 0 03-30-2011 08:45 PM
