Dtc u1016 - Road Glide Forums
post #1 of 1 (permalink) Old 03-30-2011, 08:45 PM Thread Starter
Dtc u1016
I have an 11 FLRTX.
I installed new handlebars and farkled up some wiring. I have re-wired everything and replaced parts that I messed up...what a debacle.
My turn signals and brake lights aren't flashing although they are getting power because they do run as running lights. I already replaced the front brake light switch also in case you were wondering.
I have DTC U1016. I read in the sticky that it has to do with the ECM (at least that's the case for the 2010's and I assume it is the same for the 2011's).
Is this something I can fix, or do I need to schedule a trip to the stealership? Please help.
twr05 is offline
04-07 DTC Codes ironmark Troubleshooting for Road Glides 5 09-01-2015 12:31 AM
Error Code U1016 Loss of ECM Serial Data Q-Hog ECM/Fuel Management systems 6 05-16-2013 12:29 PM
2010 DTC Codes ironmark Troubleshooting for Road Glides 15 06-18-2012 12:41 PM
07-09 DTC Codes ironmark Troubleshooting for Road Glides 2 04-03-2011 12:26 PM
Dtc u1016 twr05 Troubleshooting for Road Glides 4 04-01-2011 01:00 PM
