Fuel Gauge Fluctuation? - Road Glide Forums
post #1 of 8 (permalink) Old 04-02-2011, 05:12 PM Thread Starter
Hi folks, I have a (new to me) 2001 Electra Glide (injected) and the fuel gauge is fluctuating. swinging from almost full to half to 2/3 full. Any suggestions for troubleshooting?
Thanks!
'04 RG Impact Blue
RC Cycles Big Block
Baker 6 Spd DD
Barnett Scorpion Clutch
110 hp / 103 ft/lbs
Pokerstar is offline
post #2 of 8 (permalink) Old 04-02-2011, 05:40 PM
Ditch's Avatar
Check grounds and connections
Sent from my PC36100 using Tapatalk
FOR THOSE WHO CAME HOME...
FOR THOSE WHO DID NOT COME HOME...
FOR THOSE WHO HAVE YET TO COME HOME...
1997 FXD(P) STOCKISH
1999 FXSTDC TO MODIFIED TO KEEP RUNNING
2011 FLRTU just starting the mods
Zummo 665
HD Air deflectors
Sancho's wings
Cee Bailey's 14in light tint
HD hammock seat heated
HD ajustable back rest
cup holder
Jackpot 2-1-2 with SE Fatshotz
Power Vision
Ditch is offline
post #3 of 8 (permalink) Old 04-02-2011, 08:04 PM
staush's Avatar
Never seen a harley fuel gage worth a crap! Mine doesn't leave the full mark till i've used 2 gallons of gas. Then it goes up and down till almost empty then drops like a rock. I rely on my odometer to let me know when it's time to fill up. A little bit of figuring and you'll never run out. Just keep track of your milage for a couple of tanks and you'll have it down pat.
Staush
staush is offline
post #4 of 8 (permalink) Old 04-03-2011, 09:49 AM
HD-DOC's Avatar
Its the fuel gauge, you need to replace it if you want the wild swings to stop. Doc Not the sending unit!
HD-DOC is offline
post #5 of 8 (permalink) Old 06-28-2017, 10:53 AM
Thumbs down
just joined I hope these answers are not indicative of what are on the rest of the post. I need a good answer to how to change or fix my fuel gauge problem.
Shark2 is offline
post #6 of 8 (permalink) Old 06-28-2017, 02:37 PM
UT_Larry's Avatar
If you don't already have one get a HD service manual. It has detailed trouble shooting & replacement information. On my 97 EG after reading about the fuel gauge I chose not to repair. Was not worth the time or cost. Used the trip meter & reserve petcock
UT_Larry is offline
post #7 of 8 (permalink) Old 06-28-2017, 02:55 PM
Bleachey's Avatar
  1. A couple of good suggestions on how to search for an issue and a work around
  2. It's an internet forum free to join
  3. Your 1st post is criticizing the forum, not real sure you are going to fit in around here
2011 Road Glide Ultra
Bleachey is offline
post #8 of 8 (permalink) Old 06-28-2017, 03:26 PM
[QUOTE=Shark2;4013578]just joined I hope these answers are not indicative of what are on the rest of the post. I need a good answer to how to change or fix my fuel gauge problem.
[/QUOTE
Dang, Indickative, sounds like youes self serving,
reds4 is offline
Fuel gauge, air temp gauge inop Crcarnage87 Troubleshooting for Road Glides 1 04-17-2017 07:19 PM
Tire pressure gauge & tire depth gauge cobra206 Miscellaneous for Sale 1 12-04-2016 11:37 AM
Oil temp gauge wanted (gauge only, not full kit" SickRick Wanted! (Buy or Trade) 0 04-08-2013 03:54 PM
Fuel gauge messed up SkootchNC Troubleshooting for Road Glides 3 06-23-2011 09:59 AM
Milage/ fuel gauge beaten to death Diesel32 *General Road Glide Discussions/Pictures 6 05-02-2011 12:34 PM
