Radio Volume Problem - Road Glide Forums
post #1 of 8 (permalink) Old 04-19-2011, 05:23 PM Thread Starter
I took out the battery. And after I was done changing it, I went for a ride. After a bit, I turned on the radio and had no sound. So, I got home and turned it off, then turned the bike back on w/o starting it, and the radio and volume came on? I did notice the avc was off. I don't know it that was the problem. Anyone have any other ideas. Now last year I did put in the JVC speakers and amp. So I did run the wires under the tank.
RoadGlide0611 is offline
post #2 of 8 (permalink) Old 04-19-2011, 08:45 PM
If you have added a amplifier, most likely there is a fuse at the battery for the amp and it may have popped, therefore no sound?
keno is offline
post #3 of 8 (permalink) Old 04-20-2011, 06:37 PM Thread Starter
So, if it popped a fuse, why would the volume go on when I turn the bike off and then turn it back on w/o starting the bike?
post #4 of 8 (permalink) Old 04-20-2011, 10:40 PM
The main ground wire from the amp may have been grounded to the battery, when changing the battery you may have hooked up the power but not the main ground. the amp will work pulling ground thru RCA cables or other means but not good enough when the bike is running...?????
keno is offline
post #5 of 8 (permalink) Old 04-21-2011, 04:29 PM Thread Starter
No, my ground wire is on the frame. Looks like I'm going to have to pull the tank to see if I pinched the radio wire. Just don't know how it would work at all if I did that, but I don't know what else to do.
post #6 of 8 (permalink) Old 04-23-2011, 02:40 AM
KrashKatz's Avatar
Did you make sure the speaker switch on the forks was in the on position?, or the wires going to the switch aren't loose?
If it's upside down and burning, you've gone too fast.
KrashKatz is offline
post #7 of 8 (permalink) Old 07-03-2011, 08:01 AM Thread Starter
I had two people on this forum ( I can't find them now to thank) that told me the same thing happened to them when they put in the J&M amp and speakers. They told me it was my battery. It needed to be replaced. I had issues with the battery over the winter, and since I had it recharged, it turned the bike over but real slow. So, I thought what the heck, buy a new battery. Probably need one anyway. Well, I haven't had a issue at all with no sound coming from my speakers since I replaced my battery. And the bike starts so fast now. So, thanks to all that gave me personal pm's and posted here. This is a great forum!
2009 Hot Red Sunglo, 107 build, S&S 551 cams, heads polished and ported, Vance & Hines Dresser Duals, Vance and Hines 4" rounds, REVOLUTION PERFORMANCE ems, Bad Seed bars, J&M amp and rokkers speakers, Sony DSX-S310, progressive 940's
post #8 of 8 (permalink) Old 07-03-2011, 09:34 AM
The AVC will affect the volume level on the radio.
Biketronics right speaker volume problem Arthur Audio 9 06-09-2016 11:03 AM
Volume issues with HK radio in iPod mode Batbiker Troubleshooting for Road Glides 14 07-07-2013 08:13 PM
radio goes max volume in headphones upstater Troubleshooting for Road Glides 0 04-14-2012 08:57 PM
GPS Volume Problem JohnnyG Audio 7 04-06-2012 09:45 AM
volume won't adjust on radio sometimes Saxobject Troubleshooting for Road Glides 6 05-10-2011 10:45 AM
