How tight should head pipe nuts be? - Road Glide Forums
post #1 of 10 (permalink) Old 04-21-2011, 07:48 PM Thread Starter
I put on new head pipes on my bike, and the question is can I torque them down real tight, or should I be worried about striping it. I"m asking because one bolt seemed like it was a lot looser than the others. Of course it was the hardest one to reach. So I had to use an open wrench to tighten it down. Just trying to make sure I don't have an exhaust leak.
Thanks t
RoadGlide0611 is offline
post #2 of 10 (permalink) Old 04-21-2011, 08:17 PM
cestaro's Avatar
Thumbs up
when i did mine i notice they where not ever tight to begin with so i just snug them up and no problem you can also go back to tighten
cestaro is offline
post #3 of 10 (permalink) Old 04-21-2011, 08:35 PM
hotrodad's Avatar
RoadGlide0611
Here is what my service manual says....
● Using a long 1/2 inch swivel socket, tighten the top nut of the front cylinder head exhaust flange to 9-18 in-lbs (1-2 Nm). Tighten the bottom nut to 100-120 in-lbs (11.3-13.6 Nm). Final tighten the top nut to 100-120 in-lbs (11.3-13.6 Nm).
● Tighten the bottom nut of the rear cylinder head exhaust flange to 9-18 in-lbs (1-2 Nm). Tighten the top nut to 100-120 in-lbs (11.3-13.6 Nm). Final tighten the bottom nut to 100-120 in-lbs (11.3-13.6 Nm).
hope this helps
2005 FLTRi
Black Pearl
Live to Ride ~ Ride to Live
hotrodad is offline
post #4 of 10 (permalink) Old 04-21-2011, 11:46 PM
CHAINSAW's Avatar
Originally Posted by hotrodad View Post
RoadGlide0611
hope this helps
This is exactly right,.. BUT once your done take the bike out for a nice 10 mile or so trip around. Come back and while its HOT re torque to the specs again. The heat will loosen everything and if you don't retorque when its hot you could lose a exhaust nut later down the road. And those are no fun to try to find, especially on a holiday weekend when no auto parts stores are open. Ask me how I learned this valuble information Its also why I always keep a couple extra packed in my saddlebags, just incase.
Such is the rule of honor.
CHAINSAW is offline
post #5 of 10 (permalink) Old 09-06-2011, 09:08 AM
ameleo's Avatar
Just installed V&H power duals and tightened nuts to speck with new V&H gaskets, Problem is that I have a slight exhaust leak. Flanges are just about flush with the head. Question, should I order new gaskets and reinstall, double gasket or ???.
Just a note, I cleaned the port and seat well before the install. The leak is hardly noticeable.
ameleo is offline
post #6 of 10 (permalink) Old 09-06-2011, 09:32 AM
Radioactive's Avatar
+1 Chainsaw. Spent half a day trying to find some for my wife's Sportster.
Radioactive is offline
post #7 of 10 (permalink) Old 09-06-2011, 09:44 AM
even a slight exhasut leak can cause problems and eventualy burn a valve.
I have found it is hard to beat stock exhaust gaskets.
jeff is offline
post #8 of 10 (permalink) Old 09-06-2011, 10:05 AM
I used the Screaming Eagle gaskets for my install #17048-98 because the way the stock ones are designed my head pipe didn't want to seal up properly, my V&H instuction even mentioned that they would be needed. Chainsaw is correct and that is what I did after my installation.....
twowheel99 is offline
post #9 of 10 (permalink) Old 09-06-2011, 10:45 AM
OldNerdGuy's Avatar
In a pinch Lowes has nuts with the right threads, jus not shoulder nuts. You have to add a washer. It works but it ain't pretty.
OldNerdGuy is offline
post #10 of 10 (permalink) Old 09-06-2011, 11:05 AM
Smile
[QUOTE=OldNerdGuy;122045]In a pinch Lowes has nuts with the right threads, jus not shoulder nuts. You have to add a washer. It works but it ain't pretty.
That's where I found them.
Decatted head pipe vs. new head pipe. bear25314 *General Road Glide Discussions/Pictures 25 10-10-2014 01:41 PM
Stuck Tight Wimpy Intake and Exhaust 7 10-03-2012 04:48 PM
Too loose and too tight Howardsternspenis Do-IT-Yourself 12 06-13-2012 02:07 PM
How Tight...? Ernster500 Windshields 3 03-28-2012 12:59 AM
Well nuts - How tight? Ozoneman Windshields 12 05-12-2011 07:45 PM
