Breather blowing oil ? - Road Glide Forums
post #1 of 11 (permalink) Old 04-23-2011, 08:14 AM Thread Starter
I am getting oil blowing on my pipes from the breather.It is a 2009 RG with stage 1 se breather installed by dealer when bought new and now only 14,800 miles. My oil level is at normal per manual.What would cause this,do i need to have the dealer check it since its still under warrenty?
raven006 is offline
post #2 of 11 (permalink) Old 04-23-2011, 08:34 AM
Howardsternspenis's Avatar
Too much.......
.....oil.
It has to go somewhere when the oil pressure goes up.
Howardsternspenis is offline
post #3 of 11 (permalink) Old 04-23-2011, 09:14 AM
BDMastiff's Avatar
Originally Posted by Howardsternspenis View Post
.....oil.
That was my first thought unless your breather was not properly installed.
1996 Fatboy
BDMastiff is offline
post #4 of 11 (permalink) Old 04-23-2011, 09:17 AM
2 bike Mike's Avatar
Alot of people have had this problem. It will quit when it gets enough blown out. When it does you need to check and not fill oil past that point. It sounds crazy, but it works. I've talked to guys that have been told from their dealers to run it anywhere from a 1/2 qt to a quart low. That sounds like a lot. From my experiance the bikes I've had this happen to, the oil level was only about 1/4 quart....
2013 Vivid Black Road Glide Custom, 19" contrast cut Agitator, Black V&H with chrome tips, V&H power duals head pipes, 14" apes, black hand levers, and Joker Machine grips, braided cables, Ventilator, J&M Rokker 7.25", Hogtenna, custom painted inner fairing w/airbrushing, LRS shield, Mean City Cycles reworked Sundowner seat, drivers backrest, saddle bag spoilers w/run/brake lights, run/brake tribar.
2 bike Mike is offline
post #5 of 11 (permalink) Old 04-23-2011, 11:56 AM
dklanecky's Avatar
Happened a lot on my 09 until I finally figured out to run it 1/2 quart low, and keep the K&N air filter serviced more ofter (every 5k). Now I never have a problem.
73 Sporty - Sold
07 Sporty - Sold
09 Vivid Black Road Glide (FLTR) with ABS, Security, Fuelmoto Satge One, Clearview, Harley Hammock Seat, Hogg Chopps Lowers, Bright Ass Tail Light, SERG Headlight Bezel, Detachable King Tour Pak, Painted Inner Fairing, Cruising Southeasten Wisconsin, Delivered 3/6/2009:clap:
09 Black Fat Bob (FXDF) in Vivid Black of course, Delivered 5/1/2009
dklanecky is offline
post #6 of 11 (permalink) Old 04-23-2011, 12:03 PM
Admin
BillyBob's Avatar
yep-too much oil. They use to over fill my sporty and that happened all the time
BillyBob is offline
post #7 of 11 (permalink) Old 04-23-2011, 04:44 PM
Well also happen if you get on it hard a lot, anything over 3000 RPM will cause it.
scsharp2260
'09 Road Glide
PC V w/ Auto Tuner
Bub Series 7 Stealth Mufflers
scsharp2260 is offline
post #8 of 11 (permalink) Old 04-23-2011, 05:28 PM Thread Starter
Thank all for your replys,im glad its something that simple Ill be doing my next oil change in a couple days.. SO 3 1/2 QUARTS
raven006 is offline
post #9 of 11 (permalink) Old 04-24-2011, 02:53 AM
Do 3 1/4 qts when you do a oil change then if you need more you can add oil. The dipstick reading cold oil should not be over the 1/2 mark when bike is on the jiffy stand. Even if you set the oil at the correct amount you will have some come out of the breather at a extended period of high RPM.
post #10 of 11 (permalink) Old 04-24-2011, 08:15 AM
dklanecky's Avatar
Yeah, and when it's overfilled, the wife's turkey baster makes a great "tool" to remove some excess oil. You might want to make sure you buy her a new one before next Thanksgiving!
73 Sporty - Sold
07 Sporty - Sold
Blowing oil outta SE breather Lucky D *General Road Glide Discussions/Pictures 10 03-03-2014 11:21 PM
WTT-Black Heavy Breather for Chrome Heavy Breather MAG150 Parts for Sale 1 01-26-2014 06:15 PM
Blowing Rear Turn Signal Bulbs FLTRX kclaar *General Road Glide Discussions/Pictures 16 04-29-2013 04:04 PM
Watch out for Blowing Signs Captain13 Safety Area 3 03-04-2013 04:53 PM
blowing ignition fuse drmudd Troubleshooting for Road Glides 4 07-31-2012 06:02 PM
