How do you remove the radio antenna cable? - Road Glide Forums
post #1 of 12 (permalink) Old 04-28-2011, 09:38 PM Thread Starter
I've got a "new to me" 08 Anniver bike.
Installed a detachable luggage rack and
the old antenna is in the way.
I've removed the front fairing in anticipation
of installiing a hidden antenna which just
arrived in todays mail.
What else might I have to remove to
take out the old antenna cable to the rear fender?
Do I have to take off the gas tank?
Anybody who's done this, I'd appreciate a
little assistance on how to properly do this.
NoChute is offline
post #2 of 12 (permalink) Old 04-28-2011, 10:35 PM
From what I remember the antenna cable is bunched up with some wires. You would have to take the tank off for sure, and peel the tape off the harness. It's lots of work.
robertg is offline
post #3 of 12 (permalink) Old 04-29-2011, 11:09 AM Thread Starter
Humm, sounds like a pita. I'll save this job for another day then.
For now I'll just put this chrome cap on the antenna mount and
tie up the old radio end antenna plug inside the fairing.
NoChute is offline
post #4 of 12 (permalink) Old 04-29-2011, 11:22 AM
Vettster's Avatar
I just did mine when I installed the hidden antenna.
You need to take the tank, seat, left saddlebag and side cover off.
Trace the cable from front to back. Disconnect the cable from the back and trace it to the front.
Under the seat, the wiring harness makes several bends so you need to straighten it out in order to pull the cable thru.
I ended up cutting mine somewhere near the middle and pulling the respective pieces out of the wiring harness.
Ride Safe,
Vettster
Vettster is offline
post #5 of 12 (permalink) Old 04-29-2011, 11:22 AM
Why don't you just cut the cable off as close as you can, if you are putting another ant. on anyway.
scsharp2260
'09 Road Glide
PC V w/ Auto Tuner
Bub Series 7 Stealth Mufflers
scsharp2260 is offline
post #6 of 12 (permalink) Old 04-29-2011, 12:39 PM
RoadGlideRider's Avatar
I just coiled mine up and left it under the side cover.
RoadGlideRider is offline
post #7 of 12 (permalink) Old 04-29-2011, 02:03 PM
harley75's Avatar
What he said. Why create extra work for yourself?
75 Superglide
04 Texas Chopper
10 RGC
harley75 is offline
post #8 of 12 (permalink) Old 04-29-2011, 02:06 PM
wachuko's Avatar
Cool
+1.. keep it simple man...just leave it alone in place... not like it weights a ton anyway... so no real benefit of taking it out.
Ride Safe! Wachuko - 2016 HD Softail Slim S / 2016 Triumph Thruxton R
2014 RK CVO Tribal Orange-Galatic Black (Gone) / 2013 HD Forty-Eight in Ember Red Sunglo (Gone)
wachuko is offline
post #9 of 12 (permalink) Old 05-04-2011, 03:39 PM
That antenna and trunk light wiring cable coils up to the rear of the fuse box on my 2010 RGC. You might want to leave it there in case you find the hidden antenna performs poorly on AM, or someday you decide to put lighting on the rear trunk or feed the LED lights on an airfoil luggage rack. Remove it and you loose the option for both.
Gary
Bike33 is offline
post #10 of 12 (permalink) Old 05-04-2011, 04:44 PM Thread Starter
I have decided to leave it in place for possible future use.
Thanks for the input from all.
NoChute is offline
Remove Rear Antenna- Add Hidden Antenna- Hurt Reception? scottrgs Audio 4 09-06-2017 11:34 AM
If you're running an amp, what did you do for an antenna? anonymous_1 Audio 17 08-31-2016 02:11 PM
Remove Antenna Studs TourPak Gary R Do-IT-Yourself 1 04-05-2015 04:00 PM
how to remove clutch cable from perch? kyle31490 Controls & Handlebars 13 07-14-2014 10:40 PM
How do you remove silicone from paint? SMSgt B Paint & Bodywork Section 13 04-02-2013 09:48 PM
