6 gear light-no cruise? - Road Glide Forums
post #1 of 7 (permalink) Old 04-29-2011, 01:17 AM Thread Starter
I have a strange problem, 3 times today I would shift into 6th gear but get no gear indicator light, no big deal; except that every time it did it I could not set my cruise. Any ideas
scsharp2260
'09 Road Glide
PC V w/ Auto Tuner
Bub Series 7 Stealth Mufflers
scsharp2260 is offline
post #2 of 7 (permalink) Old 04-29-2011, 07:45 AM
Roadie09's Avatar
Check the connection where the PCV plugs into the ECM. On mine, corrosion developed on the pins and the light/cruise would not work. Clean the contacts, coat with dielectric grease and put it back together. That solved my problems anyway.
Roadie09 is offline
post #3 of 7 (permalink) Old 06-04-2011, 09:23 PM
Any new ideas on this? I now have this problem, and I have cleaned the terminals and applied dielectric grease and I still have the problem. I hate to take it to the dealer.
rc_chico is offline
post #4 of 7 (permalink) Old 06-04-2011, 10:02 PM
Have you done any work to the bike lately ? Keep us up dated on this. It looks like it might be a common problem.
post #5 of 7 (permalink) Old 06-05-2011, 01:55 AM
My bike just did this very same thing last week. It cleared when I shut the bike off, and back on again.
Jeff
akjeff is offline
post #6 of 7 (permalink) Old 06-05-2011, 07:49 AM
digga25's Avatar
Check the codes,if something is wrong it should show up on the speedo.
digga25 is offline
post #7 of 7 (permalink) Old 06-05-2011, 09:33 AM Thread Starter
Keith from Fuel Moto helped me fix mine. It was caused by the PC-V. He had me go in and uncheck the box that said get data from ECM. That being said Dyna Jet said that I needed to get my ECM re flashed with the latest update. So if you don't have a PC-V then expect that would be your answer.
scsharp2260
'09 Road Glide
PC V w/ Auto Tuner
Neutral light on cruise not working and gear indicator not showing Xman247 Tools and Garages 7 08-11-2018 12:09 PM
red cruise light, no cruise piggs Troubleshooting for Road Glides 1 05-08-2014 06:47 PM
No 6th gear light, no cruise scsharp2260 ECM/Fuel Management systems 5 01-17-2013 03:14 PM
PCV no cruise or 6 speed light Waynedj ECM/Fuel Management systems 3 09-07-2011 12:45 PM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 06:02 PM
