Bag vibration - Road Glide Forums
post #1 of 4 (permalink) Old 05-04-2011, 11:34 AM Thread Starter
NakedSnowman's Avatar
Bag vibration
Ok....16K on my beast and it's almost time to celebrate it's 1yr of ownership. My wife has notice a bit of sound vibration from the bags. No, it's not because of my sound system...She noticed it when the music was off. Any better option for securing the bag brackets better? I'm definitely not doing the screw option for the bags to the brackets....I like being about to take mine off at a moments notice especially for adding air to shocks for 2up and tourpack addition.
NakedSnowman is offline
post #2 of 4 (permalink) Old 05-09-2011, 01:04 PM
Check the brackets that actually hold the bag to the bike. Mine came loose and I tightened and put a dab of locktite on the bolts. There have been several posts about this and one guy actually lost a bag going down the road. Duane5157
duane5157 is offline
post #3 of 4 (permalink) Old 05-09-2011, 01:42 PM
SharkNose's Avatar
If you haven't done already, also check what's inside the bags. One small item can make alot of noise if its not wrapped up or whatever?
SharkNose is offline
post #4 of 4 (permalink) Old 05-09-2011, 01:53 PM
Moderator
BLKNCr6's Avatar
See my post down in "Do It Yourself" for the Dazus Keepers. Those o-rings I pictured there tighten those Dazus Fasteners right up, and kinda help dampen some vibrations.
Tried to post a link to it here but only succeeded in messing up that thread.
Use the blue loctite on those bracket bolts too...
Might check the rubber pads on the bottom of your bags...they do wear with the grit and grime of the road and the exhaust heat. If they contact the bar, they will make noise.
...and I used to think my Sportster was heavy...
A Harley will get you through times of no sex, better than sex will get through times of no Harley.
2011 FLTRU
SE Heavy Breather
V&H Monster Ovals
SE Pro Super Tuner to make the above play nice together.
BLKNCr6 is offline
Boom Wire Harness, Saddle Bag lid bra, Mid Frame Air Deflectors, Saddle Bag Wing Tip BDMastiff Parts for Sale 4 05-16-2014 10:31 PM
adding Nostalgic saddle bag rails and slotted bag fillers ge6280 Do-IT-Yourself 8 05-24-2012 10:23 AM
FS:Saddleman S2200 sissy bar/backrest bag plus removable roll bag. ichiban Classifieds Archive (3 months old+) 1 12-14-2011 12:35 PM
Falcon Black Bag and Top Bag mernstmac Classifieds Archive (3 months old+) 3 04-30-2011 11:56 PM
