Shaking - Road Glide Forums
post #1 of 13 (permalink) Old 05-06-2011, 05:56 AM Thread Starter
Shaking
I have a 2011 RGC with Harley 19" front rim and 18" rear. Both tires are Harley Dunlop. I intentionally used Harley wheels and tires to avoid any problems with ride and handling. I also chromed the fork and when I did I asked the tek to replace the stock fork oil with Screaming Eagle oil. When I am riding at 70 mph or more the fairing starts to shake...the faster I go the worse it gets! I have dyna bead in the front tire, changed the front tire, going to change the fork oil back to stock today and see if that is it! Going nuts with this....anyone have any thought please? Thank you!
Twowheels131 is offline
post #2 of 13 (permalink) Old 05-06-2011, 11:13 AM
I would lean towards the steering head bearings not adjusted properly. You did have a lot of front end work done that required the front end to be taken apart so that is were I would start. I can't see how the fork oil would come into play with this issue. The next thing I would look at would be the Dyna beads in the tire you may want to remove them and balance the wheel with conventional weights.
post #3 of 13 (permalink) Old 05-06-2011, 12:08 PM
I agree I don't see how it could be the fork oil. The steering head bearings are easy enough to check if you have a lift.
rc74racer is offline
post #4 of 13 (permalink) Old 09-02-2011, 10:51 AM
koryu2u's Avatar
Would a front fork stabalizer bar help in this situation?
koryu2u is offline
post #5 of 13 (permalink) Old 09-02-2011, 10:58 AM
wachuko's Avatar
That should not be an option at first... he should try to find what the real culprit is before installing parts that hides/mitigate the issue without addressing the root cause of the problem.
Just imho of course...
Ride Safe! Wachuko - 2016 HD Softail Slim S / 2016 Triumph Thruxton R
2014 RK CVO Tribal Orange-Galatic Black (Gone) / 2013 HD Forty-Eight in Ember Red Sunglo (Gone)
wachuko is offline
post #6 of 13 (permalink) Old 09-02-2011, 11:04 AM
Redfish-Joe's Avatar
Head bearings maybe. Dyna Beads. doubtful. I have run then for over 200k in different bikes with absolutely no adverse effects. Longer tire life and even wear is all I got as long as I stayed on top of proper inflation.
BTW the fall away should be set between 1 and 2 swings on your model.
Redfish-Joe is offline
post #7 of 13 (permalink) Old 09-02-2011, 11:10 AM
Do one thing at a time, and pick the simple items first. High speed shakes are usually the fault of a out of balance issue. Remove the front tire and take out the dyna beads and have it balanced and re-install the tire and take it for a test ride. If the shake is gone that's great if not go to the nexted item that was changed or taken apart. The fork oil may cause a harsher ride but it shouldn't cause it to shake, if you have a bike jack check the fall-away and see if its correct if not have it corrected by the dealership or indy or corrected it yourself (its spelled out in your service manual). Everyone can make mistakes, check to see if the tires are mounted correctly and check the air pressure. I'm betting it's a tire balance issue!!!!!
twowheel99 is offline
post #8 of 13 (permalink) Old 09-13-2011, 03:51 AM
My 09 shakes at 40 mph
My question is why does my 09 shake at 40 mph when you take your hands off the bars. I had given thought to a steering dampener but I have asked others and was told this was normal. Bike is bone stock. nothing has been done to it never dropped or wrecked. Proper air pressure in the tires. Need help
fatkid is offline
post #9 of 13 (permalink) Old 09-13-2011, 04:17 AM
BlackBetty11's Avatar
Now that is a ongoing thing with RGs.... I think there in noone here that does not have that. I asked my stealer to check into that... then he told me that he could, but I would have to pay for it, since HD has not come out with a recall on that. Then, as he said, it might move the problem up in speed, to where the shake would come later at 75 or 80 MPH...... But who takes their hands off the bars at those speeds. But then since he just got a RGCSE I think he might look into it now too.
2011 FLTRU103Cali
2006 XL1200C
If only my job would understand that I have other things to do!!!
H.O.G. First International Free Chapter
Green Knights Chapter 27
BlackBetty11 is offline
post #10 of 13 (permalink) Old 09-13-2011, 04:37 AM
tmd
Like others have said, get rid of the dyna beads and balance the tire wheel assembly.
tmd is offline
Violent Front End Steering and Handlebars Shaking on My CVO Road Glide Ultra 2011 CVO RG Troubleshooting for Road Glides 74 07-26-2017 12:45 AM
Daymakers shaking BklynRGU Lighting 20 04-11-2014 12:14 PM
front end shaking hellme RG2012 Troubleshooting for Road Glides 5 10-05-2012 04:37 AM
07' engine shaking, what motormount to use? ehc0720 Troubleshooting for Road Glides 15 08-22-2012 09:16 PM
Front End shaking bluebanditglide Tech Area 5 08-09-2012 04:50 PM
