Grease smell after a long ride?? - Road Glide Forums
post #1 of 4 (permalink) Old 05-15-2011, 11:33 PM Thread Starter
2010 FLTRX's Avatar
When I take a long ride (maybe...75 miles or more) I start to get a faint whiff of what smells like bearing grease. The only thing I can think of that could be causing that odor is the wheel bearings getting hot.
Anyone else ever experience this?
Sal - 2010 Vivid Black FLTRX
2010 FLTRX is offline
post #2 of 4 (permalink) Old 05-16-2011, 09:12 AM
I don't think it is wheel bearing grease. You may have some grease coming out of the steering head bearings which is not uncommon when the weather gets warmer. The grease will fly back onto the engine while you are riding. You may find some grease on the fender as it will drip out when the bike is parked. It is better to have the steering head bearings greased and have to do a little clean up then to run dry bearings. The steering head bearings take a lot of grease so when the weather warms up the grease will get thinner and this is when the grease will drip out of the steering head bearings.
post #3 of 4 (permalink) Old 05-16-2011, 10:32 AM
+ 2 on the head bearing grease. I had the same problem.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #4 of 4 (permalink) Old 05-16-2011, 11:03 AM
brhodea's Avatar
IRONMARK,
noticed you're around the area, curious if you will be able to join us for a ride on the 22 of this month here is the link - https://roadglide.org/showthread.php?t=6448
Sorry to hijack this thread but I was unable to send you a PM
brhodea is offline
HELP?? Tranny bolts loosened up after long ride home!! Ma$$hole *General Road Glide Discussions/Pictures 19 07-30-2015 11:33 AM
Gas smell after riding Sethjamto *General Road Glide Discussions/Pictures 11 02-08-2012 07:51 PM
grease fitting for headbearing???? cestaro Tech Area 12 10-14-2011 04:52 AM
Thoughts after 1st long ride after upgrades 08Zinc *General Road Glide Discussions/Pictures 9 10-12-2011 08:47 AM
Grease Drips from the.......Pic Nevadasun *General Road Glide Discussions/Pictures 8 09-23-2011 12:37 AM
