Ping and Stutter - Road Glide Forums
post #1 of 11 (permalink) Old 05-22-2011, 06:21 PM Thread Starter
whispanic's Avatar
Ping and Stutter
Ive been out getting familiar with my fltru this weekend. I have about 450 miles on it now. Ive noticed a couple of times that I get a stumble when Im pulling away from a light. Today it actually pinged and almost stalled.
Side note: That cylinder deactivation thing is pretty weird. Feels like a thumper.
Anyways, its damn near a hundred hear already and only getting hotter.
Enlighten me please.
whispanic is offline
post #2 of 11 (permalink) Old 05-22-2011, 06:25 PM
2010 FLTRX's Avatar
Sounds to me like you're overheating the bike. How long are you idling the bike that the cylinder cut off is kicking in?
Sal - 2010 Vivid Black FLTRX
2010 FLTRX is offline
post #3 of 11 (permalink) Old 05-22-2011, 06:28 PM Thread Starter
whispanic's Avatar
It kicks in within a few seconds Id say.
My sporty used to run real hot.
This 103 is crazy hot. Im not sure the oil cooler does much at all.
At highway speeds yesterday I put my hand down where the air passes off the engine and it was almost too much.
For some reason I figured the bigger jugs would run cooler. Dunno where I got that idea but it made sense at the time!
post #4 of 11 (permalink) Old 05-22-2011, 06:48 PM
SharkNose's Avatar
You've probably thought of this already whispanic, but i just want to make sure you have the lower fairing vents open in heat like that. Not that it will help you when idling/stopped, but just incase they're closed when you moving faster.
Other than that, I'd think you either need to do a stage1/tuner upgrade to get more fuel into engine and cool it down somehow, or think about other addons to cool the oil.
SharkNose is offline
post #5 of 11 (permalink) Old 05-22-2011, 07:13 PM Thread Starter
whispanic's Avatar
Vents are open.
I was wondering if there was any truth to a tuner helping things run cooler.
My mpgs are pretty bad right now so Im cautious about making it any worse.
35 first tank. 38 next tank.
Freer flowing breather help anything?
Coming off off 2 liquid/fan cooled bikes this is a new thing for me
post #6 of 11 (permalink) Old 05-22-2011, 07:42 PM
Sometimes when this happens, it's because it doesn't kick in the other cylinder fast enough. I turned off my "cooling aid" cylinder cut out and the problem went away. Some thing to check any way. Keith at Fuel Moto turned me on to the problem.
scsharp2260
'09 Road Glide
PC V w/ Auto Tuner
Bub Series 7 Stealth Mufflers
scsharp2260 is offline
post #7 of 11 (permalink) Old 05-22-2011, 07:50 PM Thread Starter
whispanic's Avatar
Hmmm...
I wondered if that was a possibility. I thought maybe the the cylinder without fuel was off time being cooler or something.
I service commercial laundry equipment for a living. I tend to think way outside the box on some stuff.
I may look into a fan in the future but if a remap would help Ill consider that first cause its cleaner looking with a fan hanging off the side.
post #8 of 11 (permalink) Old 05-23-2011, 07:29 AM
Gonekat's Avatar
Originally Posted by whispanic View Post
Hmmm...
Your gonna need a full Stage 1, not just a remap. Harley runs thie bikes VERY lean to meet EPA. Less fuel makes the bike run hotter. As for the MPG, that will get better as it breaks in. Another thing, (and Im sure you know this, but this would cause poor fuel economy and pinging) run the top grade fuel, 91+
Good Luck
Gonekat is offline
post #9 of 11 (permalink) Old 05-23-2011, 10:29 AM
T-BO 399's Avatar
Whenever I sit very long I usually give the throttle a little rap to kick the rear cylinder back on just befor I take off. It really seemed to help me on the hotter days
2009 FLTR, BLACK PEARL
T-BO 399 is offline
post #10 of 11 (permalink) Old 05-23-2011, 11:03 AM
Take the lowers off, HD recommends they come off for seasonal temps like that,
we remove them down here in FL when it starts into the mid to upper 80's consistently.
Over 90 and you're asking for a hot engine, just can't get enough air.
I'd also make sure you are running a good Vtwin 20W-50 Synthetic (reminds me I'm due to change oil) and get a tuner on it like the new powercommander from Fuel Motousa.com talk with Jamie about one if you like plug n play ride away type stuff
Or a TTS Mastertune which is close to plug n play but allows you to tweak the
map to the bike while riding and do a little fine tuning...
"My rule of life prescribed as an absolutely sacred rite smoking cigars and also the drinking of alcohol before, after and if need be during all meals and in the intervals between them." Winston Churchill
Hotroadking is offline
Stutter at 70-90 MPH on WOT? HogPro *General Road Glide Discussions/Pictures 1 07-15-2015 05:39 PM
TTS tune question - ping in 5th and 6th modot66 ECM/Fuel Management systems 6 02-20-2015 08:24 AM
Strange ping when hard on and off throttle dennisnyhc Troubleshooting for Road Glides 0 05-13-2013 08:55 AM
TTS MasterTune Map to stop Ping and high heat 2011 RGU? Raiderse ECM/Fuel Management systems 15 05-10-2012 02:52 PM
ping... Ping... PING philmartin *General Road Glide Discussions/Pictures 20 07-25-2011 10:10 PM
