Front Brakes (or lack of) - Road Glide Forums
post #1 of 5 (permalink) Old 05-28-2011, 09:28 AM Thread Starter
I have a 2001 SERG. The front brakes are bothering me. The lever has a very long throw before the brakes start working. They work good, just a while before they do. I have drained and bled the fluid two times with fresh dot 5 fluid and no help. I am sure there is no air in the lines. The pads have pleny of thickness left. They are Harley oem pads. What can I try next to get less lever throw before the brakes start grabbing? Thanks!!!
roadglide77706 is offline
post #2 of 5 (permalink) Old 05-28-2011, 09:59 AM
the pistons in the calipers could be dirty and hanging its a common problem since there are no dust boots the brake dust and other grime cause them to not move freely , there is a cleaning procedure here http://www.lyndallracingbrakes.com/service_tech.htm
I would try that first.
Eagle
Eagle is offline
post #3 of 5 (permalink) Old 05-28-2011, 01:56 PM
jimmyo79's Avatar
is the brake lever OEM? I had the same problem with some after market levers in that the throw was way long. i put the OEM levers back on and the throw was normal.
Jimmy O.
100th Anniversary Glide
No Ride like a Low Ride Glide!!
jimmyo79 is offline
post #4 of 5 (permalink) Old 05-28-2011, 03:30 PM Thread Starter
OEM levers. Just got the bike a month ago. Guess I will take apart and clean good to see if that helps. Thanks!!!
post #5 of 5 (permalink) Old 05-28-2011, 11:20 PM
+Eagle They have some great info & ther pads are top shelf
2011 FLTRX 103 Sedona Orange
Hillglide is offline
Lack of windshields for 2017 Road Glide dshudson *General Road Glide Discussions/Pictures 14 02-10-2017 10:10 AM
Lack of umpfff RustyNutz Intake and Exhaust 0 07-25-2016 10:41 AM
My lack of dyno tune faststan ECM/Fuel Management systems 7 02-18-2014 10:11 PM
Lack of stereo volume Brian C Audio 8 08-13-2011 10:48 AM
