Windshield vibration - Road Glide Forums
post #1 of 9 (permalink) Old 05-30-2011, 11:29 PM Thread Starter
Anyone else have a windshield shake or vibration at about 1500-1800 rpm? It's just the shield,not the fairing. Started doing it last year at around 30,000 miles. I've tried tightening and loosening the shield screws but neither makes any difference. Driving me crazy! Any suggestions would be appreciated.
acexp02 is offline
post #2 of 9 (permalink) Old 05-31-2011, 01:23 AM
staush's Avatar
windshield
See bad vibration on decell posted today in troubleshooting
staush is offline
post #3 of 9 (permalink) Old 05-31-2011, 01:48 AM
MyloFiore's Avatar
What kinda shield? I suspect some are worse than others, depending on the thickness.
Mylo
2011 FLTRX Road Glide Custom
2002 FXSTDI Softail Deuce (sold)
MyloFiore is offline
post #4 of 9 (permalink) Old 05-31-2011, 10:19 PM Thread Starter
It's a Clearview shield and has been on the bike almost since day one. There was no problem until last fall. Feels like it's vibrating/rattling right where it attaches to the fairing. I cut my radio brackets down this past winter and it made no difference in the vibration/rattle.
acexp02 is offline
post #5 of 9 (permalink) Old 05-31-2011, 10:58 PM
staush's Avatar
windshield vibration
Did you install rubber hose over the radio brackets after you cut them down? You need those brackets tight against the fairing to keep it from moving.
staush is offline
post #6 of 9 (permalink) Old 06-01-2011, 08:24 PM Thread Starter
I didn't put any rubber on the radio brackets after I cut them. I was already having the windshield rattle before I hacked the brackets and it's exactly the same after cutting them so I don't think that's the cause. Are you saying that the outer fairing is supposed to rest on the radio brackets for support? Mine was gouging the inside of the fairing from resting on them,so if the fairing needs this support that is one bad design!!!
acexp02 is offline
post #7 of 9 (permalink) Old 06-01-2011, 11:19 PM
staush's Avatar
Yes. On the newer models they put a stock piece of plastic on the brackets. This just prevents the long nose of the fairing from moving. When i added the rubber to my 05 it was like night and day difference. Try it, it ain't gonna hurt anything. Could be your problem.
staush is offline
post #8 of 9 (permalink) Old 06-02-2011, 01:47 AM Thread Starter
Will do..... thanks.
acexp02 is offline
post #9 of 9 (permalink) Old 06-02-2011, 02:54 AM
My WV vibrates a bit. I don't worry about it.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
bad vibration after installing short windshield rassy Windshields 7 05-07-2013 06:38 PM
Aftermarket Windshield Vibration Mink Windshields 12 02-27-2012 05:55 PM
Bag vibration NakedSnowman Troubleshooting for Road Glides 3 05-09-2011 01:53 PM
Idle vibration / cylinder unloading? hilltoptim *General Road Glide Discussions/Pictures 10 04-25-2011 11:59 AM
Floorboard Vibration jcanrun *General Road Glide Discussions/Pictures 4 03-14-2011 03:04 PM
