Engine noise at 45 RPM - Road Glide Forums
post #1 of 14 (permalink) Old 05-31-2011, 12:05 AM Thread Starter
Traveller's Avatar
I have an FLTRU 2011 and just went over 1500 miles. Lately I have noticed a sort of rattle at only certain speeds. The worst is from 40 to 50 miles per hour in 5th gear.
Anyone ever had this problem before? If you did, is it normal or what did the dealer say?
Traveller
2011 Black FLTRU
Willie G Skull's where ever I can add it.
Cee Bailey 16" Cee Glide windshield
Traveller is offline
post #2 of 14 (permalink) Old 05-31-2011, 12:53 AM
MyloFiore's Avatar
Traveller
40 MPH in fifth gear sounds like you might be bogging it down? I don't shift in to 5th until at least 55 to 60 MPH.
Mylo
2011 FLTRX Road Glide Custom
2002 FXSTDI Softail Deuce (sold)
MyloFiore is offline
post #3 of 14 (permalink) Old 05-31-2011, 02:15 AM
That sounds way to slow to be in 5th gear.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #4 of 14 (permalink) Old 05-31-2011, 05:04 AM
IdiSweden's Avatar
I'll never go lower than 2000 rpm from third gear and up. 55-60 mph when I usually go to the fifth. I never let my bike "stomping" at low rpm's.
D.F.W.T.B
2007 Performance Road Glide, 1999 "Grrrrrr!" Softail
IdiSweden is offline
post #5 of 14 (permalink) Old 05-31-2011, 07:18 AM
Gonekat's Avatar
Gear cut
Correct me if im wrong guys, but arent the 5th and 1st gears cut differently, causing them to make more noise? Aside form RPM, this may have alot to do with the noises your hearing.
Gonekat is offline
post #6 of 14 (permalink) Old 06-02-2011, 03:48 AM Thread Starter
Traveller's Avatar
thanks guys
The dealership took off the primary and checked and re-tightened everything. It was odd that i had just had my 1000 mile check up. I went with Full Synthetic oil. The service mgr suggested I go back to Normal Harley oil in the primary ... the said it is thicker? Anyway a Master Tech is going to sign it off tomorrow I hope, and I am off to Florida on Sunday.
Traveller
2011 Black FLTRU
post #7 of 14 (permalink) Old 06-02-2011, 03:50 AM Thread Starter
Traveller's Avatar
So, you all keep your RPM's up there huh? To my ear 2000 is a shift point I try to keep above it, but never really worried about it. Higher is better on a harley?
Taveller
2011 Black FLTRU
post #8 of 14 (permalink) Old 06-02-2011, 06:07 AM
Roadglide Charley's Avatar
Everyone loves to listen to harleys chug along. Especially at idle. I was on a ride with a CMA chapter on a narrow two lane backroad. I was in third gear, motoring along at speeds ranging 45 to 55. Everyone thought my bike sounded awesome. The rpm was up and I didn't wear my brakes much. Need to slow, let off the throttle and slow down.
Just my thoughts
Roadglide Charley is offline
post #9 of 14 (permalink) Old 06-02-2011, 08:19 AM
2010 FLTRX's Avatar
Taveller
2k is way to low to shift. I usually shift at 3k or higher depending on how much I'm into the throttle. At 45 mph, I'm only in 3rd or maybe 4th gear. I don't hit 5th until at least over 55-60mph.
Sal - 2010 Vivid Black FLTRX
2010 FLTRX is offline
post #10 of 14 (permalink) Old 06-02-2011, 08:24 AM
staush's Avatar
Ditto on the above. Have always shifted around 3000 rpm.
staush is offline
Cold start engine RPM on 107 engine 96349 Engine Related 3 11-07-2017 08:22 AM
Rattling Noise at high RPM Bleachey Troubleshooting for Road Glides 5 02-29-2016 09:06 AM
Opinions: M&P 45 vs XDm 45 Wharf Rat General Off-Topic Discussions 35 10-21-2014 11:44 PM
Engine idle RPM? mandlbarrett Troubleshooting for Road Glides 2 07-05-2012 08:12 PM
Loss of Mileage, engine seems to be 'seeking' an RPM, Cruise is failing Timinfla2 Troubleshooting for Road Glides 18 04-26-2011 05:08 PM
