Fork Oil - Road Glide Forums
post #1 of 15 (permalink) Old 06-01-2011, 08:59 PM Thread Starter
pte359's Avatar
Fork Oil
Ok what weight oil will give the best feel... Mine has bottomed out a coupl of times lately...how much does it take in each side??
I will be doing it myself which should not be a problem on the jack or lift..got both. This will probably get a number of options but I am looking for firm not spungy ..
Thanks in advance...
PROUD USAF Dad.....
pte359 is offline
post #2 of 15 (permalink) Old 06-01-2011, 09:02 PM
showtime's Avatar
I went with screamon eagle heavy duty oil and 10.5 to 11 oz per shock... It works for me...
RIP CTV14
showtime is offline
post #3 of 15 (permalink) Old 06-02-2011, 11:50 AM
I can't stand how much the nose dives with the stock setup - good luck fixing yours and please let us know what you did.
-Tim
Timinfla2 is offline
post #4 of 15 (permalink) Old 06-02-2011, 12:12 PM
Rowdy's Avatar
Redline in mine, but I am not sure which weight/product. My indy recommended it over any lubricant from HD. It made a noticable difference over the fluid that was in my original forks. He changed it out when he installed the powder coated lowers for me.
Rowdy
Rowdy is offline
post #5 of 15 (permalink) Old 06-02-2011, 12:46 PM
houstonhdguy's Avatar
I was going to check into this when I did my 5k service...
Will switching the fork oil be enough to make a change or will it require more than that?
houstonhdguy is offline
post #6 of 15 (permalink) Old 06-02-2011, 03:06 PM
Rowdy's Avatar
It was a noticeable difference, and I am happy with it. I really can't say if will give you the difference you are looking for, but it's a start.
Rowdy
Rowdy is offline
post #7 of 15 (permalink) Old 06-02-2011, 10:32 PM
Thumbs up
I agree with Rowdy. I'm a big guy and it made a big difference to me. I'm in Chicago and the city roads can be pothole conventions 9 months of the year, and coupling that with being 6'2" - 225lbs, I bottomed out te front end more than a couple times.
I'm on a 2006 and I imagine that the lower Road Glide Customs (and the Street Glides) won't feel as big a benefit because they have less suspension travel to work with in the first place. That extra inch and half of travel is a LOT when you're bottoming it out.
I used H-D Heavy Fork oil and it worked great. You can make your own fork seal driver by taking an appropriate diameter PVC pipe and cutting a + or x from one end into the pipe some distance lengthwise. This way you can bend the ends in to fit inside the walls of the fork tube, and then strike that with a hammer to drive your seals in safely. Beats spending the money for the special tools...
Savoir-Faire is offline
post #8 of 15 (permalink) Old 01-29-2012, 06:08 PM
fork seal driver
Can anyone tell me how many mm the forks are on an rgu? Bike is in storage but I am getting everything together to do a swap on lower forks. I already have a 41 mm seal driver from doing a softail.
Thanks Brian
Brian C is offline
post #9 of 15 (permalink) Old 01-29-2012, 06:21 PM
JJSW1283's Avatar
Thanks Brian
I believe they are 41mm, somebody else should chime in on this too unless im wrong. Another vote for SE Heavy oil.
JJSW1283 is offline
post #10 of 15 (permalink) Old 01-29-2012, 10:06 PM
skratch's Avatar
the customs and street glides being lower has not effect on the forks. they are the same. what weight oil you use is really personal preference. i like the se heavy. gives a firm ride without being overly harsh. others prefer a 50/50 mix of the type e and se heavy. still firmer than stock, but not quite as firm as straight se heavy.
as far as actually changing the oil, i don't go through all the hassle of taking the forks off/apart. you can easily do it on the bike. the short version is to take the drain bolt out, about 10.5 oz should come out. take the cap off the top of the fork (its 36 mm), and pour your new oil in. you may have to compress the forks a couple of times to get it past an air pocket, but it really isn't difficult to do.
my suggestion is to go with the se heavy. if you find it too firm, change it out again with the 50/50 mix.....
skratch is offline
When to change fork oil? jcanrun Suspensions 18 04-10-2014 10:54 AM
Fork Oil Ducflames904 Suspensions 9 02-13-2011 11:06 PM
Fork Oil Ducflames904 *General Road Glide Discussions/Pictures 7 12-11-2010 11:08 AM
Fork oil change pte359 Do-IT-Yourself 15 09-14-2010 05:04 PM
Front end dive and fork oil 96349 *General Road Glide Discussions/Pictures 5 05-19-2010 05:38 AM
