Be aware of the panic rev. - Road Glide Forums
post #1 of 18 (permalink) Old 06-05-2011, 10:43 AM Thread Starter
tuneAfish's Avatar
Well boys, I hate to say it and put the fear in your minds, but my 2010 FLTRX had been throwing codes and going into limp mode, the stealer wiggled the connectors and added grease. The results were fine [for a while] then the limp returned once then twice and yesterday leaving the driveway it happened... The bike took off into a panic rev, luckily MY SON! was able to shut her down before shredding one side or the other... If my kid wasn't the skilled rider from racing his entire life HD would be in a world of shit right now.
I will be returning this bike to the stealer on Monday with full intentions of having everything that controls this motor replaced with new components, and have the technician write a full report of his findings along with what happened to case the repairs.
MOST OF YOU MAY BE THINKING BY NOW, THIS 'KID" IS FULL OF SHIT. MY SON WOULD NOT TELL A STORY TO GET ATTENTION AND THERE WAS A WITNESS.
[Disclaimer] Sorry if I'm blunt, I fell off my mini bike when I was little and lost the ability to give a sh*t.
tuneAfish is offline
post #2 of 18 (permalink) Old 06-05-2011, 11:14 AM
Admin
BillyBob's Avatar
Let us know what you find out.
Will keep a watch out for more
Like this .
Sent from the Droid using Tapatalk
BillyBob is offline
post #3 of 18 (permalink) Old 06-05-2011, 11:16 AM
DemonCity's Avatar
Interesting!!!!!!!
1%DFFD1%
DemonCity is offline
post #4 of 18 (permalink) Old 06-05-2011, 11:24 AM
Moderator
BLKNCr6's Avatar
revrun in the 2011 threads posted a similar issue lately...connected?
...and I used to think my Sportster was heavy...
A Harley will get you through times of no sex, better than sex will get through times of no Harley.
2011 FLTRU
SE Heavy Breather
V&H Monster Ovals
SE Pro Super Tuner to make the above play nice together.
BLKNCr6 is offline
post #5 of 18 (permalink) Old 06-05-2011, 12:23 PM Thread Starter
tuneAfish's Avatar
Can you link me to it? or whar thread is it posted in?
post #6 of 18 (permalink) Old 06-05-2011, 02:28 PM Thread Starter
tuneAfish's Avatar
Today's findings:
Codes
P1510-Throttle actuator control limited performance
P2122-Twistgrip position sensor 1 low/open
P2138-Twistgrip position sensor correlation error
Looks like both the throttle control and TPS are the culprit. The question is: Did they fail or is it connections or both???
Just as an adder here, I wont be giving up and heading to Honda...
post #7 of 18 (permalink) Old 06-05-2011, 03:03 PM
WickedRican's Avatar
Are you still able to return her under lemon law?
2011 FLTRX Black Denim with Power Pak, Cruise - delivered 04/14/2011
12" DS Klock Werks; HD Mid Frame Deflectors, FLTR Deflectors, Rider & passenger Backrest, Airwing LRack; Kuryakyn Tour Tech Highway Peg Mount w/ Trident Dually Pegs, Brake Pedal Extension; Smoke Front Signal Lenses; HG Floorboard Extensions; Radio Shack Alarm Upgrade; Raptor Antenna; Avon Blk Air Cushion Grips; Santee 14" Blk Apes
2 B installed: Black Upper Fork, Drago's BW Blk S/C/S True Duals & Mufflers
WickedRican is offline
post #8 of 18 (permalink) Old 06-05-2011, 04:09 PM
See, this is why I can't figure out why they went to TBW. It's not like weight was an issue like in sportbikes or something.
I'm actually glad I'm on a TC 88 bike. No heat issues, no TBW issues, just pump 87 octane in the tank and pour some dead dinosaurs in the cases and it's good to go.
Savoir-Faire is offline
post #9 of 18 (permalink) Old 06-05-2011, 06:58 PM
https://www.roadglide.org/showthread.php?t=7929
Seems there may be issues with the 2011 as well.
Chaz is offline
post #10 of 18 (permalink) Old 06-05-2011, 11:09 PM
Run
Guest
Mine is still in the shop for doing the same thing. I'll let you know what they tell me when I fet it back. Good luck.
Run is offline
Always Be Aware Captain13 Safety Area 14 07-30-2013 11:19 PM
PANIC STOP!!! ABS rules! Methos1979 *General Road Glide Discussions/Pictures 47 10-18-2012 05:20 PM
More aware... Sixnine68 New Members Welcome Area 5 04-08-2011 07:07 PM
