Rear Brake Switch - Road Glide Forums
post #1 of 12 (permalink) Old 06-06-2011, 02:23 PM Thread Starter
DAWG_6's Avatar
Rear Brake Switch
Looking for some help with this...a couple of weeks ago, my cruise control was having trouble staying engaged. I noticed my rear brake light was on, so I pumped it hard and it went off after I released the pedal....and the cruise works fine now.
But now my brake light will not turn on and my cruise will not disengage when I push my rear brake pedal....
I read another post where someone mentioned adusting the rear brake switch....the wires all seem to be connected.....nothing shorted out......
is this something that can be adjusted or does it need replacing?
Thanks for any help.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
DAWG_6 is offline
post #2 of 12 (permalink) Old 06-06-2011, 02:36 PM
cestaro's Avatar
you can take a volt meter and test the switch to see if is working
cestaro is offline
post #3 of 12 (permalink) Old 06-06-2011, 03:20 PM
staush's Avatar
Rear brake switch is a pressure switch . There is nothing to adjust,it's off w/no brake,closed w/brake. Most you can do is put ohmeter on it and see if it changes state when pedal is pushed.no change = bad switch.
staush is offline
post #4 of 12 (permalink) Old 06-07-2011, 02:21 PM Thread Starter
DAWG_6's Avatar
Thanks....I guess I have a bad switch...
So, let the Moto Co fix it under warranty, or is it an easy swap out? Looks like I may have to remove my exhaust to get to it. Any suggestions would be appreciated.
Also, does anyone know what size wrench this thing is??
DAWG_6 is offline
post #5 of 12 (permalink) Old 06-07-2011, 07:38 PM
staush's Avatar
Fix under warranty. Don't know if pulling switch opens hydraulic brake line or not. Check service manual.
staush is offline
post #6 of 12 (permalink) Old 06-08-2011, 01:14 PM Thread Starter
DAWG_6's Avatar
Yes, it was a bad rear brake switch. $20 part...
Yes, it is hydraulic and when you remove the old one, it opens up the brake line...so you have to bleed them when you are done.
Turned out to be a 30 minute job.....everything works fine now.....much easier than taking it in to the dealer for the warranty repair.....
DAWG_6 is offline
post #7 of 12 (permalink) Old 06-08-2011, 01:31 PM
staush's Avatar
switch
Glad it was a cheap fix.
staush is offline
post #8 of 12 (permalink) Old 06-08-2011, 01:35 PM Thread Starter
DAWG_6's Avatar
Me too.....
DAWG_6 is offline
post #9 of 12 (permalink) Old 06-08-2011, 04:28 PM
skratch's Avatar
do you have abs on your bike? i've heard that if you need to bleed the brakes with abs, you need the digital tech....
skratch is offline
post #10 of 12 (permalink) Old 06-09-2011, 03:20 PM Thread Starter
DAWG_6's Avatar
No, unfortunately, I do not. The process is very different with ABS and the manual provides procedures for both.....
You have to have the additional equipment to mess around with the ABS....
DAWG_6 is offline
Brake Levers and rear brake pedal from 2010 FLTRX (STOCK) HUTMO Miscellaneous for Sale 4 03-03-2016 06:48 PM
Help removing ignition switch. Switch seems stuck? Driftah Controls & Handlebars 5 11-04-2015 08:18 AM
Billet brake lever installed for rear brake HUTMO Do-IT-Yourself 1 12-27-2012 04:18 PM
Help Removing Rear Brake Light Switch jimmyray11349 Do-IT-Yourself 4 03-17-2012 09:52 PM
Changed rear brake arm now almost no rear brake? ncbeast Troubleshooting for Road Glides 4 05-30-2011 10:13 PM
