Close call- check your transmission cover bolts! - Road Glide Forums
post #1 of 5 (permalink) Old 06-20-2011, 08:55 PM Thread Starter
Govdog76's Avatar
I remember reading a long time ago on here about the bolts holding the transmission cover over the exhaust bracket coming loose.
Tonight I was doing a "pre flight" before my trip to the mountains, and I noticed a little film of oil on the exhaust bracket...
Sure enough, the two transmission cover bolts that also hold the bracket were finger tight at best...
tightened them as best I could with little allen wrenches, but could not do it properly because I did not have a deep socket to take off the exhaust nut. Will fix properly tomorrow (after I ride to Sears for some deep sockets).
Lesson learned- everyone check your bolts! (and nuts)
Ian
Govdog76 is offline
post #2 of 5 (permalink) Old 06-20-2011, 09:02 PM
Admin
BillyBob's Avatar
Thanks for the head's up
Sent from the Droid using Tapatalk
BillyBob is offline
post #3 of 5 (permalink) Old 06-20-2011, 09:11 PM
BroomStick!'s Avatar
Took mine in for it's 24k service on Friday, I had noticed the night before a small film of oil on the bracket but since I was taking her in the next morning for servicing... I didn't look hard to see where it was coming since it was such a small amount.
Told them about the oil and when I picked her up later that day they mentioned that those 2 bolts were missing and were the cause of the leak. Apparently they check these all the time because of the known issue with these bolts.
I'm gonna keep my eye on these from now on.
Shut up & Ride!
Shut Up & Ride!
2010 FLTRX
BroomStick! is offline
post #4 of 5 (permalink) Old 07-16-2011, 07:46 PM
Ditch's Avatar
I had a small amount of oil under my xmsn at first I thought it was the drain plug, that the last time had it in the broke or did not tighten well.
They told me it was that bracket. It is good to go now. had a buddy with a limited and it did the same thing.
So if you have a small spot of oil under your bike check the bracket
FOR THOSE WHO CAME HOME...
FOR THOSE WHO DID NOT COME HOME...
FOR THOSE WHO HAVE YET TO COME HOME...
1997 FXD(P) STOCKISH
1999 FXSTDC TO MODIFIED TO KEEP RUNNING
2011 FLRTU just starting the mods
Zummo 665
HD Air deflectors
Sancho's wings
Cee Bailey's 14in light tint
HD hammock seat heated
HD ajustable back rest
cup holder
Jackpot 2-1-2 with SE Fatshotz
Power Vision
Ditch is offline
post #5 of 5 (permalink) Old 07-17-2011, 09:06 PM
TAuston's Avatar
Shut up & Ride!
Had the same thing happen to me. Went out the other morning and oil on the carport under the bike. Looked and found that the bolts were missing from my bracket also. Got some more from the dealer and put lock tight on them. Will be checking from now on.
2010 FLTRX
TAuston is offline
Close call. Real close! dreeves *General Road Glide Discussions/Pictures 38 04-25-2017 02:23 PM
Check Your Exhaust Bracket Bolts! MakeARunMike Troubleshooting for Road Glides 5 08-03-2016 09:15 PM
Check your drive belt pulley bolts PeteInFl *General Road Glide Discussions/Pictures 16 02-04-2016 01:45 PM
check your transmission vent hose Redbeard77 Troubleshooting for Road Glides 5 08-18-2013 06:49 PM
Close Call pte359 General Off-Topic Discussions 1 01-13-2010 09:03 PM
