Oil coming out of SE Air Cleaner - Road Glide Forums
post #1 of 11 (permalink) Old 07-02-2011, 07:50 PM Thread Starter
CSM11's Avatar
I recently placed a SE Air Cleaner on my 2011 FLTRX, I have oil spitting out and while riding it get all over my saddlebag. I had the same set up on my 07 Dyna and had no issues ever. Is there a fix? Does someone make a system to take care of this blowback oil issue, Thanks
CSM11 is offline
post #2 of 11 (permalink) Old 07-02-2011, 07:57 PM
Redfish-Joe's Avatar
Just wondering what the oil level is cold on the RG. My 08 liked to run with the oil mid way on the stick. Any more and she would puke it out thru the breather.
Redfish-Joe is offline
post #3 of 11 (permalink) Old 07-02-2011, 08:00 PM Thread Starter
CSM11's Avatar
I will ck it, Where do you run your on the stick cold
CSM11 is offline
post #4 of 11 (permalink) Old 07-02-2011, 08:12 PM
Mid way. That is about 3.5 quarts on a oil and filter change.
post #5 of 11 (permalink) Old 07-02-2011, 08:37 PM
I had one of the conical SE filters and had same problem. Took it back to dealer and he checked gaskets and tightened some of the screws by the back plate and no problem since
dspencer is offline
post #6 of 11 (permalink) Old 07-02-2011, 08:49 PM
Radioactive's Avatar
Check your manual, full is half way of the dipstick when cold (both jiffy stand or upright). Any more will come out of the filter. You can siphon some out or let it burn off.
Radioactive is offline
post #7 of 11 (permalink) Old 07-02-2011, 08:49 PM
CHAINSAW's Avatar
I agree with others, your either running to much oil or a gasket is bad. Shouldn't be spitting out oil.
Such is the rule of honor.
CHAINSAW is offline
post #8 of 11 (permalink) Old 07-02-2011, 10:01 PM Thread Starter
CSM11's Avatar
level
Roger checked level I am below halfway when cold, will ck bolts in am then gasket thanks
CSM11 is offline
post #9 of 11 (permalink) Old 07-02-2011, 11:22 PM
hellbender's Avatar
This may sound silly but if you have the filter you oil up youself you may just have it over oiled? Wash it and just dust it with the spray oil. Or you may be getting some blow by, even with a new bike, no biggie it happens. Dohertymachine.com makes a power vent twin kit just for this purpos and it's trick looking too! hope this helps CSM11.
2011 FLTRU, vivid black, American Custom exhaust, Doherty Power Pacc air breather, fi2000 PowrPro fuel-injection tuner, HD Heritage Bars, Cee Baileys 15" Cee Glide windshield, FLTR Wind Deflector kit and some other little pretties too.
hellbender is offline
post #10 of 11 (permalink) Old 07-03-2011, 08:47 AM
TheDoctor's Avatar
I've had this problem on 2 bikes now. Best thought is too much oil. Drain the oil while it's hot. I'm going to start with 3 qts in my fltrx and go from there. I've heard synthetic expands more than conventional oil. It seems to push more out the hotter it gets.
2010 FLTRX
TheDoctor is offline
Oil coming from air cleaner??? Paesani241 *General Road Glide Discussions/Pictures 18 07-29-2015 02:28 AM
2013 oil coming from air cleaner Clean&Sober Engine Related 11 02-26-2014 08:13 PM
SE Stage 1 Air Cleaner Puking Oil Blue Shark Nose Intake and Exhaust 12 01-18-2014 05:17 PM
Oil from SE air cleaner? dspencer Road Glide Specific Discussions 10 07-19-2011 02:00 PM
SE Air cleaner assm for 2000 SE Road Glide 2blackbelts Aftermarket Accessories 2 11-11-2010 12:12 AM
