Trans noise - Road Glide Forums
post #1 of 21 (permalink) Old 07-06-2011, 12:00 AM Thread Starter
Trans noise
have an 11 fltrx. 100 miles so far. Trans is real noisey. when I pull in the clutch after 1st ( before actually shifting to 2nd) I hear a clank sound ?? Also getting into neutral is a nightmare. i had a six speed on my 07 and it was smooth. Does it need to break in or should I bring it back ?
THEMASTERDESTROYER is offline
post #2 of 21 (permalink) Old 07-06-2011, 09:31 AM
joke's Avatar
Check your tranny oil level first (sometimes it's low from the factory) then take it back to the dealer.
2009 Mirage Orange
joke is offline
post #3 of 21 (permalink) Old 07-06-2011, 02:54 PM
staush's Avatar
Sounds like your shifter shoes (not the ones at the end of your legs) aren't adjusted correctly. Dealer time!
staush is offline
post #4 of 21 (permalink) Old 07-06-2011, 07:37 PM Thread Starter
just checked fluid- low. hot should read in the middle of the X mark. then theres an A . my level is reading at the bottom of the A. so probably a few oz low. I dont think this would be makin all that noise.
@ staush- Can you eloborate on the shifter shoes. I have no idea how they work,. Does the trans have to come out or is this an easy adjustment ? thanks
post #5 of 21 (permalink) Old 07-06-2011, 07:54 PM
staush's Avatar
they take the cover off of the tranny to adjust the shifters. on the earlier bikes ,the service manual would show how to adjust the shoes but i tried to find it in my manual,nothing.shouldn't be any biggie.
staush is offline
post #6 of 21 (permalink) Old 07-06-2011, 09:29 PM
jbrushoe's Avatar
It sounds like the shift forks are out of adjustment. I would take it back to the dealer!! They have a special tool for that adjustment.
06 Shark Fire Red Pearl
1997 FLSTS > looking for a new home
Jim
jbrushoe is offline
post #7 of 21 (permalink) Old 07-06-2011, 09:34 PM Thread Starter
goin back tmrw. clutch is sloppy also. theres a retaining clip off the side of the gauge cluster. clip isnt there. cable is up against cluster markin it up . Not havin luck with this thing. I also posted in the paint section my saddlebag was not painted correctly.
post #8 of 21 (permalink) Old 07-06-2011, 09:36 PM Thread Starter
So are the "shifter shoes" and "shift forks" the same thing ?? just so I know what im talkin about when I go there tmrw
post #9 of 21 (permalink) Old 07-06-2011, 09:38 PM
jbrushoe's Avatar
Yes, shift forks!!! there's no shoes in there
Jim
jbrushoe is offline
post #10 of 21 (permalink) Old 07-06-2011, 09:42 PM
jbrushoe's Avatar
[QUOTE=THEMASTERDESTROYER;100987] Also getting into neutral is a nightmare.
It also sounds like your clutch is out of adjustment!!
Jim
jbrushoe is offline
Valve intake noise/cam overload noise Budd559 Engine Related 9 02-15-2016 06:23 AM
Is there anything to help with trans clunking and top end noise garzajr676 Engine Related 16 12-14-2013 05:25 PM
Noise from clutch/trans while cruising Venomized Troubleshooting for Road Glides 6 05-17-2013 08:28 PM
Baker 30 or 31 tooth trans pulley????? gabbyduffy Engine Related 36 07-23-2011 02:12 AM
Trans Lube Change Luscruz Troubleshooting for Road Glides 10 09-18-2010 08:08 PM
