voltage gauge - Road Glide Forums
post #1 of 13 (permalink) Old 07-20-2011, 06:46 PM Thread Starter
mernstmac's Avatar
Exclamation voltage gauge
does anyone else does this... when coming to a stop the voltage drops from 14 to 11 to 12 volts....???
Only a biker knows why a dog sticks his head out of a car window.
No Ride like a Road Glide...!!
mernstmac is offline
post #2 of 13 (permalink) Old 07-20-2011, 07:00 PM
JacktheBagger's Avatar
nope shouldnt drop that low ...
dont know how much "error" is built into the gauge ..
lights dim ??
hard to start ??
2011 Ultra
JacktheBagger is offline
post #3 of 13 (permalink) Old 07-20-2011, 07:03 PM Thread Starter
mernstmac's Avatar
I notice the light dim slowly and brightens back up when I give it throttle...
also I hear a loud Clunk when I restart the bike after riding for a couple of hours...
post #4 of 13 (permalink) Old 07-20-2011, 07:06 PM
Nope, mine stays at 14 anytime the motor is running.
SickRick is offline
post #5 of 13 (permalink) Old 07-20-2011, 07:06 PM
Redfish-Joe's Avatar
Look on the bright side, excuse the pun, if the stator is going out you can replace the compensator with no labor cost!!
Redfish-Joe is offline
post #6 of 13 (permalink) Old 07-20-2011, 07:08 PM Thread Starter
mernstmac's Avatar
its a 2008...
post #7 of 13 (permalink) Old 07-20-2011, 07:56 PM
sounds like it is charging OK , check the battery connections , they must be tight ..
maybe something shorting out somewhere ??
2011 Ultra
post #8 of 13 (permalink) Old 07-20-2011, 08:01 PM
SharkNose's Avatar
Per the indy shop I go to, more stators seem to go bad during high ambient heat than other issues...and we're all experiencing that right now.
I'd double-check all your connections and if not found there, time to have the stator tested.
SharkNose is offline
post #9 of 13 (permalink) Old 07-20-2011, 08:28 PM Thread Starter
mernstmac's Avatar
well tested the battery reading at 12.6 to 12.8
starting the bike I got a reading from 13.9 to 14.3
the dimming was from the bike shaking... Had my wife stand in front of it to see if the light dim... nope
but going to have the shop to make dam sure on the battery... Its the original battery from 2007
wish me luck
post #10 of 13 (permalink) Old 07-20-2011, 09:13 PM
sounds like that battery is good .. shud read 12.7 , not running and 13.9-14.3 is right for the charging ..
Harley batteries last a good while , had some go six-7 years
2011 Ultra
Fuel and Voltage gauge stopped working ronniekuiper *General Road Glide Discussions/Pictures 3 03-05-2018 12:42 PM
Voltage Gauge shows spiking above 14.1 KennyD104 Engine Related 13 10-06-2016 12:53 PM
Voltage/oil pressure gauge rdbateman Engine Related 3 10-24-2013 09:54 AM
Oil temp gauge wanted (gauge only, not full kit" SickRick Wanted! (Buy or Trade) 0 04-08-2013 03:54 PM
voltage gauge low and lights are dimming chuckp Troubleshooting for Road Glides 5 06-28-2011 12:59 PM
