No Cruise, No Brake Lights , engine light and lots of codes - Road Glide Forums
post #1 of 5 (permalink) Old 07-23-2011, 02:27 PM Thread Starter
DonJulio's Avatar
1500 Hundred Miles 2011 RGC103
Im going to assume its a bad brake switch like others have had. This is what I found for codes.
ECM
P0572 Brake Switch Low
P0031 02 Heater Low/Open - Not sure what this one means
TSM/TSSM/HFSM
b1122 Right Turn Output Fault
Speedometer
b1006 Accessory Line overvoltage - Not sure about this one either
Tachometer
ABS
C1094 Front Brake Switch always on
C1214 Rear Brake Switch always on
DonJulio is offline
post #2 of 5 (permalink) Old 07-23-2011, 05:16 PM
Howardsternspenis's Avatar
Unhappy Sounds like....
.....a short.
Have you put any new electronics on before the problem started?
Howardsternspenis is offline
post #3 of 5 (permalink) Old 07-24-2011, 08:30 AM Thread Starter
DonJulio's Avatar
I may have a couple things going on, I do have a brake switch issue. the rubber boot was hanging up the front brake switch, Fixed that and now even if i wiggle the lever up and down the brake lights go on. The cruise still doesnt work. I think I may have screwed that one up while attempting to install the chrome switch caps. Im going to reset the codes today and see what happens.
DonJulio is offline
post #4 of 5 (permalink) Old 07-24-2011, 05:36 PM
Redfish-Joe's Avatar
May have a pinched wire on the right side.
Redfish-Joe is offline
post #5 of 5 (permalink) Old 07-24-2011, 06:02 PM
The cruise won't work with brake trouble codes present or if the brake switch is sending a signal.
engine light on no codes help Roadking03 ECM/Fuel Management systems 1 09-16-2018 06:25 PM
Check Engine Light/No Cruise after Bar Installation macabra11 Controls & Handlebars 5 03-24-2018 09:05 PM
red cruise light, no cruise piggs Troubleshooting for Road Glides 1 05-08-2014 06:47 PM
no turn signals, brake lights, or power to cruise MoRob Troubleshooting for Road Glides 4 07-02-2012 10:23 PM
No cruise or brake lights pigfixer Troubleshooting for Road Glides 3 08-21-2011 11:18 PM
