Stock RGU Air Shocks not holding - Road Glide Forums
post #1 of 4 (permalink) Old 07-27-2011, 01:18 AM Thread Starter
b104396's Avatar
Anyone else have problem on their 2011 RGU of shocks not holding pressure? Just finished 2400 mile trip with wife and every morning pressure read zero and would re-inflate to 50 psi. By mid day could tell most of the pressure had been lost. Mentioned to dealer on last service and they said pressure held overnight but bike not ridden or loaded with two up and full bags. Bike is going in next week for 5k service and I want to force issue with dealer to fix or replace.
2011 103" RGU Merlot Sunglo V&H Rounds, SERT, Fullsac X Pipe, SE/AC, SE255 cams,Brightass, IPOD Kit, Zumo 660, Hammock, Heritage Bars, Bag Guards, Tire Presssure Monitoring.
b104396 is offline
post #2 of 4 (permalink) Old 07-27-2011, 01:33 AM
Shark daddy's Avatar
There is a hose leak or faulty boot in one of the shocks, could even be a slow leak in the valve stem. They should hold air indefinitely with no drop in pressure. Ask the dealer to look harder and take it for a reasonable test ride. Good luck. Shark Daddy from Portland, ORE
Shark daddy is offline
post #3 of 4 (permalink) Old 07-27-2011, 01:53 AM
Mine do not loose any air pressure over time but they still don't feel great. I had progressive 440's on my past bike and am going to go that route or something similar in the future.
jeff is offline
post #4 of 4 (permalink) Old 07-27-2011, 11:04 AM
DED HD's Avatar
Mine were leaking or not holding air at all. The hose was rubbing on a sharp edge of the frame on the left side of the bike where it goes under the seat causing a hole in the hose. Simple fix, by replacing the hose.
'10 Red Custom:
DED HD is offline
Want your reasons for not running air shocks adown Suspensions 4 06-18-2016 06:09 PM
DC dealer holding a Nation of Islam ride??????? DC-3Mek General Off-Topic Discussions 23 09-04-2015 07:19 AM
So Much for HD holding their value over Metric bikes ironmark *General Road Glide Discussions/Pictures 30 04-04-2014 11:42 AM
Leaking air shocks - New Works Shocks RoadGlide5150 Equipment-RG 0 10-29-2010 04:04 PM
