Overheated my glide today. Opinions? - Road Glide Forums
post #1 of 32 (permalink) Old 07-28-2011, 01:12 AM Thread Starter
On the 27th i was riding home to Chicago from Manitowoc, Wisconsin. The first half of the day was storms and cold, but down by Chicago it was 98 degrees and I was trapped in stop and go traffic for quite a while. I heard what I initially thought was valve clatter, then thought was engine knock. Not cool.
Then I noticed a loping idle and that my voltmeter was reading around 12.5, ranging up to 13.7 when under load. Crap. I kept a sharp eye on it, and then 20 minutes later it begged at 11.2, my check engine light came on as well as the red battery light. Crap.
I made it home, turned it off, let it sit for a few, and then restarted the bike. I fired, but not happily. I shut it down, let it be for 3 hours and then checked it again. This time it fired up like nothing was wrong. No more check engine light, voltmeter reading normal, no more loping / fluctuating idle, nothing.
Do I test it out and if it's ok, just put it down to overheating? Opinions?
Savoir-Faire is offline
post #2 of 32 (permalink) Old 07-28-2011, 08:17 AM
Denim Glide11's Avatar
The first thing I would do especially if your not running synthetic oil, is change the oil.
Second off you did not mention what year bike any mods.
Personally I would change the oil and see what happens, if it everything runs fine I would leave it alone, if not then I would check into it.
Denim Glide11 is offline
post #3 of 32 (permalink) Old 07-28-2011, 08:52 AM
What year is your bike? The loping should be the heat management system kicking in, the heat management feature will shut down the rear cylinder so there is less heat produced. The bike will be running on the front cylinder only and it will sound like it, as soon as you give the bike some throttle the rear cylinder will start firing again. Overheating the engine will cause a spark knock situation and when you hear that it would be time to pull over and let the bike cool. Last year I went through Chicago and got caught in stop & go traffic and it was near 100 degrees outside, the oil temps on my bike went up to 267 degrees, I changed the oil & filter the next day, I run Mobil 1 20w50 v-twin oil and I believe that the synthetic oil helped protect the engine. Your bike should be just fine IMO.
post #4 of 32 (permalink) Old 07-28-2011, 11:00 AM Thread Starter
I have an '06, so there's no EITMS system (I think that's what the "run on one cylinder" thing is called). I have slip ons, and nothing else, so I'm probably lean to begin with and that's not good for heat, I know. Bike was like that when I bought it. I plan on doing the air filter and a Power Commander over the winter. Not sure if the ECU has been reflashed; I bought the bike used.
I'm not on synthetic, and I plan to change the oil and filter today. After this change I'm probably going to go to AMSOil or Mobil-1 synthetic. I'll put another 5 K or so on between now and the end of the year (I hope).
post #5 of 32 (permalink) Old 07-28-2011, 11:29 AM
until you can get another tuner you might want to check the Xied's from Nightrider
I have not used them ( my 01 has a carb) but have heard good things about them making the bike run better /less lean .
Eagle
Eagle is offline
post #6 of 32 (permalink) Old 07-28-2011, 07:01 PM
Roadie09's Avatar
You would be surprised at the amount of abuse these engines can actually take (concerning heat).
I would change all of the fluids and than give it a test ride to see how it acts. If you have good oil pressure and no warning lights, you will most likely be fine.
Roadie09 is offline
post #7 of 32 (permalink) Old 07-28-2011, 07:23 PM
You haven't heated a bike up until you've been stuck in Sturgis traffic when it's hot out there. Oil pressure drops to zero and the bike is too hot to sit on. I love the smell of burning clutches in the afternoon...:-)
I can't believe your bike was damaged by heat. I'm not saying that your electrical problems aren't heat related, but I really doubt you damaged the motor.
SickRick is offline
post #8 of 32 (permalink) Old 07-28-2011, 07:27 PM
after the first time it goes into its overheat mode hit the kill switch if only for one minute while in traffic and every time you stop. this works for me ,it stays alot cooler and heat managment system stops kicking in
2011 RGU .SE stage 1, Reinhart true duals,Klockwerks windsheild,black air wing,bullet lights,chrome handle bar switches,gauge rings,shifter&brake pedals etc
captain ade is offline
post #9 of 32 (permalink) Old 07-28-2011, 08:13 PM Thread Starter
Yeah, everything is looking a-ok over here. I wasn't scared of hurting the engine, I just thought I might have fried a voltage regulator or something. No big deal. Bike seems fine, and I'm going to take it for a longer ride than 3 blocks soon to make sure I'm good.
I think I just freaked out for no reason. Thanks for the kill switch thing, btw; sounds like a good idea. Or option two, move the hell out of this city (soon!)
post #10 of 32 (permalink) Old 07-28-2011, 11:30 PM
Brando's Avatar
How hot does the engine have to get before the heat management system shuts off the rear cylinder? I was stuck in stop and go tonight on the way home from work in 85 degree heat for an hour and a half and don't think the hms ever kicked in. I do have it set according to the owners manual. I shut the bike down a couple of times, maybe for no more than 30 seconds each time. My legs were frying but I never noticed the bike to act any different while sitting still.
2010 Denim Black FLTRX, Stage 1, V&H Pro-Pipe, 2011 saddle.
Brando is offline
Wrecked my Road Glide, looking for opinions. nsampson *General Road Glide Discussions/Pictures 33 05-03-2018 07:58 AM
Overheated in Montreal philmartin *General Road Glide Discussions/Pictures 12 08-20-2014 10:15 PM
Just Raised My Fairing Today On My 2008 For The Vented Fairing Lowers ironmark Paint & Bodywork Section 2 09-04-2012 08:25 AM
way! anybody ride today? tell us about it? (cold ride today) jeffb928 *General Road Glide Discussions/Pictures 40 04-02-2012 11:19 PM
Overheated SHRFF1 General Off-Topic Discussions 4 08-14-2011 10:33 AM
