A few questions regarding SE Tuner, and other issues. - Road Glide Forums
post #1 of 11 (permalink) Old 07-29-2011, 07:03 PM Thread Starter
Here's what I got, 2011 RGU SE airfilter(open) and FatKatz silp-ons and SE Tuner.
The other day while riding to work about 80mph with the cruise on the cruise kicked off and would not resume, thou the throttle worked fine. Shut the cruise off and tryed again, work for about a minute and kicked off again.
After I noticed engine light on, every thing seemed fine with exception of the cruise.
When I got home I ran a code scan (thanks IronMark) found Cruise limits high, both EGO sensors rich and non-responding. The cruse I believe is a faulty switch, but my question is the EGO sensors. Could or would the SE tuner disable the EGO sensors when used to tune for changes?
The bike is going in to have this checked being it's still under warranty, I would just like some backup info on these issues. Thanks for any input.
Butch is offline
post #2 of 11 (permalink) Old 07-30-2011, 10:25 AM
Exactly what is your codes, what do you mean by EGO sensors? Could you mean o2 sensors or ECU, ECM. If your bikes ECM recognizes a code that is related to the function of the engine it will shut down the cruise option on the bike, it is one of the many ways that the ECM will do to protect the engine. I would not think that it would be in the cruise control switches and controls. It may be a 1 time only occurrence. Did you try to clear the codes to see what happens? If you clear the codes and you ride the bike and no codes come back & everything works fine then it may have been a minor grounding problem, if the codes reappear then you have a issue that should be taken care of by a HD tech because the bike is still under warranty.
post #3 of 11 (permalink) Old 07-30-2011, 01:01 PM
HD_Shock's Avatar
The cruise switch (in the handlebar) has been known to be problematic in newer bikes. Mine went out at 1000 mi. Switch replaced and no trouble since.
Here's a thread that touches on it. https://www.roadglide.org/showthread.php?t=4763
-phil
2011 FLTRX 103
HD_Shock is offline
post #4 of 11 (permalink) Old 07-30-2011, 08:39 PM Thread Starter
EGO= exhaust gas oxygen sensor or o2 sensor.
The codes PO132,134,152,154, and PO577.
I,ll clear the codes and see what happens and report back with what I find.
Thanks for the reply's
Butch is offline
post #5 of 11 (permalink) Old 07-30-2011, 10:09 PM
Sounds like the front & rear o2 sensors are reading a rich A/F mixture or they are not functioning properly. It may be a result of the o2 heaters not functioning properly. Make sure the plugs going to the o2 sensors are making a good connection.
post #6 of 11 (permalink) Old 09-17-2011, 06:37 PM Thread Starter
Ok after got the bike back from the dealer, they check the codes, and cleaned the pcm connection and 02 sensors connection and a reflash, everything seems ok.
Guess I should keep contact cleaner on hand.
Thanks for the input guys.
Butch is offline
post #7 of 11 (permalink) Old 09-18-2011, 09:48 AM
Also the cruise on my bike won't set over 80mph, I am not sure but I heard that HD change the upper limit on the cruise on the newer models.
post #8 of 11 (permalink) Old 09-18-2011, 11:47 AM
Radioactive's Avatar
Mine is a 2010 with a race tuner and I've had it set at at over 90mph before. Maybe with the 2011's and later?
Radioactive is offline
post #9 of 11 (permalink) Old 09-18-2011, 11:55 AM
HD_Shock's Avatar
Max cruise on my 2011 is 90 mph - any higher and you're on your own.
-phil
2011 FLTRX 103
HD_Shock is offline
post #10 of 11 (permalink) Old 09-18-2011, 12:15 PM
BlackBetty11's Avatar
Imo anything over 90mph on Cruise is insane anyhow. But I also had some issues with mine. But I noticed that the problem started after I put other bars on the Bike.
2011 FLTRU103Cali
2006 XL1200C
If only my job would understand that I have other things to do!!!
H.O.G. First International Free Chapter
Green Knights Chapter 27
BlackBetty11 is offline
Installed of SE 254 cams & other SE parts Hillglide Engine Related 2 04-23-2017 12:52 PM
Vance & Hines Power Duals, SE Pro Tuner, SE Heavy Breather, OEM (stock) mufflers Methos1979 Intake and Exhaust 7 06-20-2015 08:40 PM
Jensen HD1BT won't hold clock setting and other issues? chevjerico Audio 10 02-16-2015 08:02 AM
SE tuner and Power Vision tuner question bigshaqa *General Road Glide Discussions/Pictures 8 01-11-2015 10:35 PM
HD Super Tuner vs HD SE Street Perf Tuner mhud3780 ECM/Fuel Management systems 1 02-18-2013 11:00 AM
