Chirping sound - Road Glide Forums
post #1 of 11 (permalink) Old 07-30-2011, 06:55 AM Thread Starter
Kevian's Avatar
Chirping sound
On the way home from work yesterday, I noticed a chirping sound whenever I went over "bumbs" in the road. Nothing severe, it wasn't like I was running through potholes. Has anyone else experienced this?
Kevian
Kevian is offline
post #2 of 11 (permalink) Old 07-30-2011, 07:16 AM
Redfish-Joe's Avatar
Check your belt tension. A "too tight" belt can cause chirping.
Redfish-Joe is offline
post #3 of 11 (permalink) Old 07-30-2011, 09:07 AM
+1. I agree
post #4 of 11 (permalink) Old 07-30-2011, 09:45 AM
Brewiz's Avatar
Also check your muffler clamps and heat shields. A buddy of mine had the same thing, got to the point that it was scary to ride because it made so much noise. We took the slip-ons off re-installed them and retightened the heat shields, finally got it...
Brewiz is offline
post #5 of 11 (permalink) Old 08-01-2011, 03:57 PM
Check the muffler hanger brackets that hold up the rear of the muffler. There is a rubber bushing in there that dries up and can cause "chirping" noises. Just grease it up a little and you should be good to go.
Stryke1 is offline
post #6 of 11 (permalink) Old 08-01-2011, 08:01 PM
fltrx103's Avatar
Mine was a loose baffle in my slip-ons...a few turns with the allen wrench..no more "chirping" noise....Hopefully its something simple like that for you
2011 FLTRX103..Vivid Black, Mirror chrome Agitator wheels 19/18, Jackpot 2-1-2 head pipe, S/E A/C, Klock Werks S/S shorty slip-on mufflers, Mustang seat 10"WV shield, H-D vented lower fairings.
fltrx103 is offline
post #7 of 11 (permalink) Old 08-01-2011, 08:49 PM
Shark daddy's Avatar
You may want to check if you have a parakeet stuck between the forks and the front brake caliper. I did going to Sturgis last year, but it was dead!
Shark daddy is offline
post #8 of 11 (permalink) Old 08-01-2011, 09:15 PM
OldNerdGuy's Avatar
Dead, but still chirping... IT'S A MIRACLE
OldNerdGuy is offline
post #9 of 11 (permalink) Old 08-01-2011, 09:17 PM
DemonCity's Avatar
+1............
1%DFFD1%
DemonCity is offline
post #10 of 11 (permalink) Old 08-01-2011, 09:59 PM
CHAINSAW's Avatar
+1 on the muffler clamps,.. mine still does it every once in a while on the right side.
Such is the rule of honor.
CHAINSAW is offline
Chirping sound when decelerating bless0 Tech Area 14 12-26-2017 09:19 AM
Electronic Security Alarm Flashing and Security Alarm Chirping When Ignition Switch I aklowrider Troubleshooting for Road Glides 2 05-03-2016 03:26 AM
Chirping noise in new header ??? hotrod_rick1 Intake and Exhaust 4 04-20-2014 12:25 PM
chirping noise on gear change gja Troubleshooting for Road Glides 10 04-19-2014 09:14 AM
chirping noise on deceleration cballjr54 Troubleshooting for Road Glides 13 10-21-2010 08:46 PM
