lighter - Road Glide Forums
post #1 of 3 (permalink) Old 12-24-2013, 02:48 PM Thread Starter
lighter
I've installed a lighter in the glove box and I'm wanting to know if I can tap off existing lighter ? I was going to use the extra wire coming off the headlight, but it looks like it will be needed for the day maker.
Thanks
2004 Road Glide, 1993 BMW K 75s
1983 HD 883, 19 ? Suzuki gs 750, 19 ? Honda 500
Hutch is offline
post #2 of 3 (permalink) Old 12-24-2013, 07:33 PM
cobra206's Avatar
U can tap the existing lighter or you can use the headlight lead. Either way will work. If u want to use the headlight lead u can just add a couple of pigtails in case u want to add the day makers later...
Sent from Motorcycle.com App
cobra206 is offline
post #3 of 3 (permalink) Old 12-24-2013, 10:33 PM
I put power ports in both glove boxes and still kept the lighter functionable. I made a wiring harness that came from the lighter power to both power ports, because I don't use all 3 outlets at the same time the exsiting fuse works well.
Cigarette Lighter for GPS ??? Tek74 Aftermarket Accessories 12 12-24-2011 01:16 AM
Cigarette lighter not working correctly RIDERED67 *General Road Glide Discussions/Pictures 11 06-01-2011 10:27 AM
cigarette lighter Sancho Aftermarket Accessories 17 04-26-2011 10:24 PM
Which fuse for the cig lighter... jupiter Troubleshooting for Road Glides 6 04-08-2011 09:38 AM
Zumo and Cigarette Lighter mtatl *General Road Glide Discussions/Pictures 10 09-29-2010 01:47 PM
