outlet in tour pack - Road Glide Forums
post #1 of 8 (permalink) Old 12-28-2013, 05:11 PM Thread Starter
outlet in tour pack
Added a outlet to my detachable tour pack.
So easy, A caveman can do it...
2004 Road Glide, 1993 BMW K 75s
1983 HD 883, 19 ? Suzuki gs 750, 19 ? Honda 500
Hutch is offline
post #2 of 8 (permalink) Old 12-28-2013, 06:57 PM
I'm a caveman!
2013 RGU, black of course....
y2kflhr is offline
post #3 of 8 (permalink) Old 12-30-2013, 09:24 AM
WHEEEE thats just what i need thanks
Craig A is offline
post #4 of 8 (permalink) Old 01-10-2014, 05:08 PM
boots's Avatar
How did you end up mounting it insde the tour-pak ? I would'nt like it just flopping around in there....
2013 RG Custom / Candy Orange / Wind Splitter Windshield / Razor Tour-Pak with 4 Point Docking Sys / Short Sissy Bar and Pad / Jackpot 4" Mufflers / Fullsac DX Head Pipe / Screamin Eagle Heavy Breather / TTS Tuner / H-D Chrome Enforcer Wheels 19" and 16"
boots is offline
post #5 of 8 (permalink) Old 01-10-2014, 05:24 PM
ERod62's Avatar
Tour pack setup I changed the quick disconnect for water tight and hook it to the battery with a fuse for the mounting location my cable reach to the pouch so can secure charging devices and when not used cover on for safety. Ran the cable along the other disconnect for easy tour pack removal.
Sent from Motorcycle.com App
ERod62 is offline
post #6 of 8 (permalink) Old 01-10-2014, 06:28 PM Thread Starter
I'm just leaving it lay loose in the tour pack. I had a amp in the tour pack prior, just came thru the bottom.
Hutch is offline
post #7 of 8 (permalink) Old 01-11-2014, 05:45 PM
Q-Hog's Avatar
Nice addition. I was planning on doing the same but I like your plug better than the one I have..
Q-Hog is offline
post #8 of 8 (permalink) Old 01-11-2014, 06:03 PM
RichieRich's Avatar
Same one we use on my wife's sporty on trips. Using the pigtail for the trickle charger makes it easy.
2013 BBP FLTRX
RichieRich is offline
anyone install the saddlebag power outlet? ChromeYellow67 Aftermarket Accessories 9 02-01-2013 06:05 PM
Adding Accessory Outlet jimmyray11349 Do-IT-Yourself 1 11-27-2012 09:16 AM
Aux outlet Oldman47 Do-IT-Yourself 3 06-21-2012 09:15 PM
Cheap & Easy 12V outlet jimmyray11349 *General Road Glide Discussions/Pictures 10 05-07-2012 08:16 PM
Tour-Pak 12V acc outlet Runamuck Aftermarket Accessories 2 01-02-2011 03:46 PM
