Strapping Bike to lift table for front end service - Road Glide Forums
post #1 of 18 (permalink) Old 01-18-2014, 09:01 PM Thread Starter
JayKS's Avatar
I'm a little embarrassed asking this question because it seems like it should be obvious. I recently acquired a lift table and I love it for most everything. Engine work, general service, changing the rear wheel, etc. Everything is much easier.
However, I recently swapped out my front wheel. I tried strapping down the rear, jacking up the front with a frame jack and then removing the wheel chock. I was going to have to jack it up pretty high to get the wheel/tire out from under the fender. I never could get comfortable with the way I had it set up. I eventually ended up putting the bike on the ground and using a regular MC jack to swap out the front wheel.
So, there's got to be a better way to do this on the lift table. What am I missing? How do you all do it?
JayKS is offline
post #2 of 18 (permalink) Old 01-18-2014, 09:05 PM
TimmyG's Avatar
Take the fender off? Then u won't have to go so high
TimmyG is offline
post #3 of 18 (permalink) Old 01-18-2014, 09:47 PM
FrankieB's Avatar
With my HF table with a rocking style chock I would do it on the floor also. With my titan table it has a vise chock that I can remove a bar in the front to roll the tire out of. You could try and roll it on backwards and don't use the chock at all, just strap it down good.
06 RK
11 RGU
FrankieB is offline
post #4 of 18 (permalink) Old 01-18-2014, 09:51 PM
calgaryglide's Avatar
Hello Jay,
Funny you should post this, I am in the same predicament. Have removed axle and spacers. Have the frame jack under the bike, have yet to remove the wheel chock. To top it all off i have the the lift in a corner of the shop so that I can still put in a company vehicle when the weather drops to -20 or so. So my front and left side access is very limited.
I was thinking that next time I need to do this of rolling the bike on backwards without the wheel chock on. This will take 2 people but then the second person can place the frame jack under the bike and lift the front end ever so slightly, strap the bike down overtop of the battery after taking the seat off. Raise the lift and remove the back section of the lift where you would normally remove the rear tire. Sound plausible?
Calgaryglide
2019 FLTRU, Tyggr
calgaryglide is offline
post #5 of 18 (permalink) Old 01-18-2014, 10:08 PM
Jetman's Avatar
Both my thoughts have already been presented.....Remove the fender also so you height off the table is limited - Or, get some help backing onto the table & once strapped down, you can use the drop plate the same way you do when taking off the rear......
2012 - Big Blue Pearl
Heavily Accessorized.....
Jetman is offline
post #6 of 18 (permalink) Old 01-18-2014, 10:32 PM
We use a HF table lift and remove their wheel chock in favor for the black trailer style chocks that flip forward when you roll the bike over it and locks the bike down enough to strap the bike down. Then in order to take the front end off we then take a frame jack and jack to bike up. once the tire just lifts off of the wheel chock, we pull the pins on the chock and remove the back part. Then you are able to slide the wheel out. It is the best way we found because this way one guy can do it all by themselves. Hope this helps you
RGC Vivid Black,Yaffe extended BagsRC Components "Calypso" Chrome wheels,with matching rotors,HHI Stripper Bars,CFR Slip-Ons CAT Removed
Louster47 is offline
post #7 of 18 (permalink) Old 01-19-2014, 06:40 AM
zman's Avatar
If i'm pulling the front wheel it stays on the floor and gets lifted with the scissor jack. As long as I'm able to crawl around on my knees for 10 min. thats what I'll do. I'm not overly confident any time its on the HF lift.
"I Just Cant Leave Well Enough Alone"
zman is offline
post #8 of 18 (permalink) Old 01-19-2014, 08:49 AM Thread Starter
JayKS's Avatar
Thanks for the suggestions, folks. You guys got me thinking and I think I came up with something that should work.
I'm usually working alone, so no way I'd be able to back the bike onto the lift. However, I think I can easily drill a couple of holes at the head end of the table so I can swap my ramp to that end and ride it on from the other direction. Then strap it down, raise the front slightly with a frame jack, drop the end of the table and get to work!
JayKS is offline
post #9 of 18 (permalink) Old 01-19-2014, 09:20 AM
laxinharley's Avatar
I had similar problem. I have the HF lift and a removeable chock. I get the bike in the chock, strap down and remove the chock. HF also sells a small mc jack. Rated for about 1000 pounds. It's small enough to fit under the bike on the lift table. My brother welded a piece on to go across the bike frame. I use that to get blocks of wood on the the table so she's steady and than strap her. Easy access to anything you need in the front.
laxinharley is offline
post #10 of 18 (permalink) Old 01-19-2014, 09:21 AM
That's exactly what I do but use a small jack to sit the bike on wood so I can remove and swing whole front end.
Should I get a jack lift or a table type lift MarkL *General Road Glide Discussions/Pictures 32 04-01-2017 09:08 PM
HF 1000lb lift table lift Blackbag1 Do-IT-Yourself 44 06-11-2015 05:49 PM
HF lift table coupon code rlaf75 General Off-Topic Discussions 13 07-03-2014 08:47 PM
Lift Table cheap outcast1 Miscellaneous for Sale 27 05-09-2014 02:10 PM
Harbor Freight Lift Table Coupon skratch *General Road Glide Discussions/Pictures 14 06-01-2012 09:42 AM
