Home built bike working platform??? - Road Glide Forums
post #1 of 5 (permalink) Old 01-29-2014, 07:07 PM Thread Starter
Hi I'm going to be doing some engine work on my 09 when the weather starts warming up and would like to get the bike up in that air a little. I am thinking of building a temporary platform to run the bike up on to while doing the work. Afterwards it would be disassembled and stored away or cut up and parted out for use elsewhere. Probably made of wood. Has anyone done something similar? If so can you post pictures? I do have a bike Jack but it is way to weak for large bikes like a RG.
Thanks.
Reddobe1 is offline
post #2 of 5 (permalink) Old 01-29-2014, 10:16 PM
dwsmith's Avatar
Are you close?
If you are close to southeastern Indiana I would let you use my table! For awhile at least!
2009 w/MadStad Shield,Big Sucker, Rush Slip-ons, FuelPak & Progessive suspension.
dwsmith is offline
post #3 of 5 (permalink) Old 01-29-2014, 10:22 PM
My buddy built something like that but he only used it for his sporty and dyna. Worked pretty good for what he needed. He used a bike ramp he had to get the bikes up and down it. He finally broke down and bought the harbor freight lift table.
post #4 of 5 (permalink) Old 01-29-2014, 11:37 PM
FLTRXpilot's Avatar
Thanks.
I don't have access to my pics but a while back I built 4 platforms out of 2x10 wood to put my car on to change things like drivetrain/clutch/etc. They have served me well for years and your post gave me the idea to use it for the bike too.
I basically made 2 pieces long enough to fit under the wheels with some overhang and I beamed the middle down the center length then had 3 or 4 crosspieces in there too. Or to put it another way build a 'box' frame with 2 pieces top and bottom, 2 end pieces each side and 2 pieces across the middle and one down the center lengthwise. Of course, you would not need the extra strength to hold a bike (the car is over 3300 lbs!) so less would probably work. The 2 pieces top and bottom gave me 6 inches of lift then I just used the center pieces as the lumber was dimensioned so 9 1/2 inches giving me a total of 15ish inches height. Had to see saw the car up to get it that high using rhino ramps as mid-height temps cause I didn't have a jack to lift the whole distance at once. For that matter just use Rhino or car ramps (but there is still the issue of holding the bike upright!) But after all the hassle of building the box it might just be worth it to get a stand!
You still would have to work out how to get the bike on it, how to keep the bike upright and how to move the box around when not in use. My boxes are pretty heavy and a bike is longer so your box would be bigger! Or use 2 smaller boxes and if you have a bike jack just jack the bike up and set it on two boxes (thats what I will do as I also have a bike stand that locks the front wheel that I could bolt to the front box for stability.
Just a thought...
2010 CVO FLSTSE - traded!
2013 FLTRX Black Demin,RC components slipons and HD heat shields,Black cans/bells,Mutazu lower fairing,blacked out fender struts,CVO style hard bags,J&M Rokker speakers,RF 300x2 and Soundstream Picasso 4 ch amps, Hogtunez speaker lids, kicker 6x9 3 ways.
FLTRXpilot is offline
post #5 of 5 (permalink) Old 01-30-2014, 06:52 PM Thread Starter
Thanks for the offer. But a little too far to drive.
Reddobe1 is offline
Oil Spray on front right side exhaust and platform 2016CTRoadGlide Engine Related 4 08-17-2017 10:42 AM
224HP and 194 tq Dragos built bike new record. DragoBikeWorks Engine Related 11 02-14-2012 08:49 AM
Wind deflect, Baker Built Wings hforward Road Glide Specific Discussions 9 06-14-2011 05:13 PM
