Adding a siren from Radio Shack on older models - Road Glide Forums
post #1 of 15 (permalink) Old 02-20-2014, 03:29 PM Thread Starter
FireGuy88's Avatar
So after going through the 31 pages of the "Add a Siren to your Factory Security for $6" from Dklanecky for posts on how to do it on older bikes I thought I'd start this one for those of us riding older glides. I did this on my 2006. The major difference is where the plug is for the alarm. On older models its under the right side cover of the bike, the brake lever side. Newer models its next to the fuse box under the left side cover I believe.
Step 1 - Remove brake side saddlebag and side cover
Step 2 - Remove these 2 screws shown in the first picture
Step 3 - Remove the two nuts in the 2nd picture. You'll find the alarm plug snapped into the back side of this plastic piece. You can see the clip circled in yellow.
File Type: jpg Alarm 2 Remove these nuts. Yellow shows where plug is clipped in..jpg (91.0 KB, 74 views)
FireGuy88 is offline
post #2 of 15 (permalink) Old 02-20-2014, 03:32 PM Thread Starter
FireGuy88's Avatar
Step 4 - On the back side of this plastic piece you'll see a plug snapped/clipped into it shown in this picture. The plug looks like this with 3 wires, black, green and brown. Remove this plug and remove cap.
Second picture shows plug without cap. Can't really see the color of the wires in the picture.
File Type: jpg Alarm 3 This is where the plug is on the back side of the plastic piece..jpg (93.1 KB, 56 views)
File Type: jpg Alarm 4 this is the plug with cap removed.jpg (95.7 KB, 56 views)
post #3 of 15 (permalink) Old 02-20-2014, 03:34 PM Thread Starter
FireGuy88's Avatar
Step 5 - Attach crimp on style pins to red and black wires from Radio Shack Buzzer shown in second picture. I re-did the positive wire pin and wrapped each separately with a little electrical tape to help keep them from touching each other.
File Type: jpg Alarm 6 Siren wites with crimped on pins.jpg (91.9 KB, 57 views)
post #4 of 15 (permalink) Old 02-20-2014, 03:37 PM Thread Starter
FireGuy88's Avatar
Step 6 - Drill 2 holes (or one big hole) through plug cap to allow for wires to slide through. I plan to seal these up with clear silicone as others have done. The pins will stick out of the cap once the pins are connected
Step 7 - Attach/Insert pins from buzzer wires into alarm plug. Attach RED (postive) wire to BROWN wire from plug. Attach BLACK (negative) wire to GREEN wire from plug. Again Red to Brown, Black to Green.
NOTE: The second picture is not the correct placement for the pins, they should be side by side. There should not be a wire between them, at least not on my bike. I just wanted to snap a quick picture.
File Type: jpg Alarm 7 Alarm Plug cap with hole drilled through for siren wires.jpg (92.1 KB, 47 views)
File Type: jpg Alarm 8 Slide wires through cap, plug pins into plug..jpg (92.7 KB, 53 views)
post #5 of 15 (permalink) Old 02-20-2014, 03:43 PM Thread Starter
FireGuy88's Avatar
I'll figure out where and how I'm going to attach the Radio Shack Buzzer. Might just drill a whole through the plastic piece that the plug is clipped into and screw it in. It is very loud when it goes off. When I arm the security system with my fob it gives two chirps. Disarm it gives a single chirp. Both synced with the turn signal flash. The chirp isn't loud and sounds kind of odd, like its not getting full power for the chirp. Doesn't really bother me though.
Radio Shack Buzzer: http://www.radioshack.com/product/in...ductId=2062405
Original Thread: https://www.roadglide.org/showthread.php?t=251
I hope this helps some people.
post #6 of 15 (permalink) Old 02-24-2014, 07:26 AM
jettman96's Avatar
Hey Fireguy88 Did you ever figure out why your siren wasn't working properly? I'm having a similar problem.
'98 Sportster
'08 Roadglide
jettman96 is offline
post #7 of 15 (permalink) Old 02-24-2014, 10:10 AM
'04UltraGlideguy's Avatar
Was wondering my self as I am about to do the install maybe later today
'04UltraGlideguy is offline
post #8 of 15 (permalink) Old 02-24-2014, 08:32 PM Thread Starter
FireGuy88's Avatar
What problem are you having specifically? Its going off when the battery is reconnected? Or the chirp sounds weak?
Weak chirp? Haven't figured that out.
Siren going off once connected and not being able to shut it off? Yeah I'm an idiot and had the red wire from the buzzer going to black wire on bike instead of brown. To be fair, it was kind of hard to distinguish black from brown on dirty wires!
post #9 of 15 (permalink) Old 02-24-2014, 08:36 PM Thread Starter
FireGuy88's Avatar
Also if you do this buzzer the same exact way as I did but on a different year please post it and I'll edit the first post so people know quickly. If there are any differences please post that as well and again I'll make a list of year and differences on the first post for quick reference.
post #10 of 15 (permalink) Old 02-25-2014, 06:50 AM
jettman96's Avatar
Thanks FireGuy88.
I'm working on an '08 RG. The problem I am having is that I get no chirp or alarm when I have it plugged in to the correct wires (Red -> Brown & Black -> Green). I also get the constant siren when I plug the red wire into the Black wire.
I've tested the Siren and it works great with a 12v source.
I got out the voltmeter and checked at the plug:
Green & Black = 12v
Green & Brown = ~1v (when the alarm should be activated)
I do see my flashers blink when engaged and when tripped, so, I know TSSM is at least engaging the lights and I can tell when the siren should at least be making some noise.
Guess I'll be tracing wires next... yeah!
'98 Sportster
'08 Roadglide
Radio Shack Piezo Siren 12vdc Bruckus Parts for Sale 3 05-10-2015 10:19 AM
Radio Shack Alarm R0ckie *General Road Glide Discussions/Pictures 4 04-05-2015 11:39 PM
Radio a Shack siren = LOUD!!! Howardsternspenis Do-IT-Yourself 13 10-12-2013 07:25 AM
Question on the Radio Shack alarm mod Methos1979 Do-IT-Yourself 11 10-08-2012 03:18 PM
Problem with Radio Shack alarm sanders Do-IT-Yourself 7 09-24-2011 02:30 PM
