Saddlebag lid tether mount posts cracked - Road Glide Forums
post #1 of 3 (permalink) Old 08-17-2014, 01:32 PM Thread Starter
fragmentum's Avatar
I am doing some preventative maintenance for our upcoming trip and discovered the saddlebag tether mount posts on the underside of the lids are cracked and want to repair them. I repaired some cracks on the inner fairing mount posts some time back and don't remember what material (glue, epoxy....) I used on them.
I am open to suggestions on how you repaired yours...
If your not living on the edge, you're taking up too much room...
fragmentum is offline
post #2 of 3 (permalink) Old 08-17-2014, 01:56 PM
I would try repairing them like you would repair the stripped threads on the upper fairing hole.
Mix up some JB weld and and put a release agent on the screws (I use cooking spray such as Pam) then put the JB in the holes and screw in the screws and after the JB sets up pull the screws. You may want to let the JB setup real good before putting everything back together.
post #3 of 3 (permalink) Old 08-17-2014, 02:06 PM
bucketlisthd's Avatar
You could JB Weld some aluminum flashing to the outside of the crack also.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
To lid or not to lid? BlueJob Audio 4 08-22-2015 09:20 AM
Saddlebag tether screws are stripped Maleko *General Road Glide Discussions/Pictures 10 08-10-2015 03:38 PM
Cracked chopped tour pak lid with aftermarket backrest SEsupply2 Equipment-RG 0 04-27-2014 11:39 AM
saddlebag lid hinge mount hardware options? Roedog Paint & Bodywork Section 6 03-26-2014 05:37 PM
Install Tour-Pak Retractable Tether 54171-11 BLKNCr6 Road Glide Builds-Document your builds HERE --NEW 6 04-18-2011 10:01 PM
