Spark Plugs? - Road Glide Forums
post #1 of 4 (permalink) Old 07-03-2012, 01:22 PM Thread Starter
brhodea's Avatar
Spark Plugs?
Performing my 20K mile service and was curious what type of plugs y'all are using if not replacing them with OEM?
brhodea is offline
post #2 of 4 (permalink) Old 07-03-2012, 01:58 PM
glide69's Avatar
I'm running accel u-groove platinums
2018 FLTRXS Wicked Red
glide69 is offline
post #3 of 4 (permalink) Old 07-03-2012, 04:05 PM
OEM plugs are just fine. Fancy high priced spark plugs won't give you anymore performance gain IMO. Your stock plugs are probably fine with just 20,000 miles on them, look at how often you change the auto spark plugs.
post #4 of 4 (permalink) Old 07-19-2012, 10:33 PM
lh4x4's Avatar
One thing to remember when using aftermarket plugs on newer HD's is that they need to be 6 ohm resister plugs like the HD ones.
Why? The anti knock provision to protect the motor is based on the resistance in the combustion chamber and needs a resistor plug to make it work correctly.
lh4x4 is offline
Spark plugs moose1 Engine Related 31 07-12-2015 02:11 PM
20k Service & NGK Spark Plugs jimmyray11349 Do-IT-Yourself 18 08-16-2014 03:03 PM
Spark Plugs-Knock Sensor BackRoads" Charlie Tech Area 2 01-13-2013 06:16 PM
Rusty Brown colored spark plugs ChivoChavez321 Troubleshooting for Road Glides 1 11-30-2012 06:43 PM
Spark plugs ? Big Moke *General Road Glide Discussions/Pictures 9 06-03-2012 07:05 PM
