Headlight removal - Road Glide Forums
post #1 of 10 (permalink) Old 07-08-2012, 08:00 PM Thread Starter
ReferJohn's Avatar
Headlight removal
can the headlight trim ring, then headlights be removed without fairing
removal?
would like to do a headlamp bulb upgrade.
2012 RGU
thanks in advance
I have read the sticky about fairing removal.....but could not get the
info for headlight removal while still on the fairing-if this is possible on 2012.
2012 FLTRU
THAT'S WHY I'M HERE
ReferJohn is offline
post #2 of 10 (permalink) Old 07-08-2012, 08:01 PM
Evolutionscc's Avatar
Unfortunately not. You have to pull the outer fairing off
08' RG. 6" KW, painted inner, 4" drop bags/fender, 21" DNA Envy, V&H......more to com
Evolutionscc is offline
post #3 of 10 (permalink) Old 07-08-2012, 08:07 PM
hd4cruzin's Avatar
If it's a 2012, You can remove the trim ring around the lights. There are 4 tabs near each corner you insert a flat knife etc and the ring will come off.
2012 FLTRX BBP
hd4cruzin is online now
post #4 of 10 (permalink) Old 07-08-2012, 08:53 PM
RoadGlideRider's Avatar
Wrong!!
On the 2012 model the headlight can be removed without taking the fairing off.
Just remove the cover and you can get to the screws that hold the headlight shell itself.
RoadGlideRider is offline
post #5 of 10 (permalink) Old 07-08-2012, 09:05 PM
RoadieWingZ's Avatar
2012 can definitely be handled without removing the fairing. Us guys with the older models ain't so lucky .....
Road Glides Rule!!!
2009 Vivid Black FLTR, Gold Flame collection, Cee Bailey 18" TRSSC Dome, BOOM speakers, Kury FB extensions, Heritage Style bars
RoadieWingZ is offline
post #6 of 10 (permalink) Old 07-09-2012, 04:06 AM
09 was the last year the outer fairing has to be removed in order to change headlights. 10s and newer can be done without having to remove the fairing.
post #7 of 10 (permalink) Old 07-09-2012, 11:22 AM
That's a fact, I have a 2011 (son too) we changed his bulbs to HID WITH OUT removing the faring. Simply remove the bezel and take the 4 screws per light out.
2011 SilverShark RGU on Black Ice
IBA Member
2012 Tri Glide Ultra
Highway is offline
post #8 of 10 (permalink) Old 07-09-2012, 12:03 PM
while you have the fairing apart save yourself the hassle and convert your headlight backplate. I did on my 09 and it is great. Someone had a full description on here but basicly I removed the headlights from the backing plate, remounted them to the front and backed out the adjuster screws to recess the whole package. I left the bubble off and went with the 09 CVO trim. very sweet and easy.
09 Red Hot Sunglo
Forks, bells, crash bar, Saddle bag latches, Wild1's 612
J&M 7.25", Rocker Boards, Sundowner & Adj. drivers backrest, T-Man 107, Thunder Max, SE air & FatCat w/ghost
capt3017 is offline
post #9 of 10 (permalink) Old 07-09-2012, 01:56 PM
Just put a set of PIAAs in Frankies Ultra a few minutes ago. Easy Peasy! Maybe took 15 minutes.
post #10 of 10 (permalink) Old 08-04-2012, 02:34 PM Thread Starter
ReferJohn's Avatar
Using a Butter Knife i was able to remove bezel. while there replaced bulbs
with silvania silverstar ultra H4.
2012 FLTRU
THAT'S WHY I'M HERE
Headlight Amp multi connector removal Kenljk Forum Help Desk (Post Forum Issues Here) 2 02-03-2013 01:01 PM
Headlight assy removal on 2012 help ReferJohn Lighting 3 08-02-2012 11:40 PM
Headlight Assembly Removal Kerryebro Lighting 6 06-15-2012 08:36 AM
Headlight change vs. fairing removal ODA CDR (RET) Road Glide Specific Discussions 44 01-16-2012 02:51 PM
Headlight cover removal 71u140 Lighting 6 05-21-2010 02:50 PM
