Custom Dynamics LED turnsignal install - Road Glide Forums
post #1 of 66 (permalink) Old 07-09-2012, 04:09 PM Thread Starter
tkbalt's Avatar
Ordered the Custom Dynamics turn signal package for my 2012 RGC. Though I would share some photo's of the install. This is pretty effortless, something anyone should be able to accomplish. Probably took me a couple of hours (first time + taking photos). I did use a J&S lift to make it a little easier on the back.
First ordered components from Custom Dynamics - Karen was very helpful on the phone. We talked thru what I wanted and she confirmed the correct parts for my application. I ordered the package, where you can select the specific items.
I purchased the HD LED turn signal kit (GEN200-KIT-1157). You have several options to select within the kit. I selected:
Pair of amber / white front turn signal LED's
Pair of red rear turn signal LED's
A slim line load equalizer
A magic brake strobe
4 smoked lenses
When you select the package, you are prompted to make the individual selections and get some minimal discount on some items when adding them to the package. I think the kit was about $280 with the upgrades. Shipping was free.
The package:
First remove the rear lens caps and bulbs. Then insert the LED's (making sure to use a dab of dielectric grease).
tkbalt is offline
post #2 of 66 (permalink) Old 07-09-2012, 04:12 PM Thread Starter
tkbalt's Avatar
Next place the unit(s) into the bullet housing and fit the lens.
And hear they are on:
Repeat with the front turn signals...........
tkbalt is offline
post #3 of 66 (permalink) Old 07-09-2012, 04:16 PM Thread Starter
tkbalt's Avatar
Front installed - note the signals operate as white running lights (a white ring of LED's on the outside) with a cluster of amber in the center. The signals flash at a high rate of speed without a load equalizer.
Note the color of the white LED's is pretty close to my HID's - or at least closer than with the stock bulbs
tkbalt is offline
post #4 of 66 (permalink) Old 07-09-2012, 04:38 PM Thread Starter
tkbalt's Avatar
The load equalizer and the Brake Strobe look intimidating, but are simply daisy chained between the connection to the rear lights. The connection is down in there, so you have to dig for it. Once located you attach the load equalizer 1st, and the brake strobe 2nd. You do have to connect the load equalizer to the battery via a fused connection. Clean up your wires and secure the modules (I used industrial strength velcro and wire ties). I used the default brake strobe - three flashes and then solid on. And you are done. Everything is plug and play. And man are these bright.
Next up will be installation of red custom dynamics plasma rods in a run / brake / turn mode...........
tkbalt is offline
post #5 of 66 (permalink) Old 07-09-2012, 04:43 PM
ChromeYellow67's Avatar
I have the same set up, minus the strobe. Well worth the money, and you did a nice write up on the install!
2015 FLHR Morocco Gold Pearl
ChromeYellow67 is offline
post #6 of 66 (permalink) Old 07-09-2012, 04:52 PM
Jetman's Avatar
Dang- I wish I'd have known you had them when we met for lunch......I'd have paid more attention.............Definatly on my "want's " List.................
2012 - Big Blue Pearl
Heavily Accessorized.....
Jetman is offline
post #7 of 66 (permalink) Old 07-09-2012, 06:26 PM
I just put get them a couple weeks ago, didn't have em when we met! lol
Ya didn't miss a thing!
post #8 of 66 (permalink) Old 07-09-2012, 06:31 PM
Did my bike a few weeks back, almost the same.. Custom Dynamics is great to work with, I had a problem with a load equalizer and they went the extra mile to make it right. Shipped out a replacement equalizer, at not cost to replace the bad one. Great service and a hell of a product.
mpears53 is offline
post #9 of 66 (permalink) Old 07-10-2012, 06:03 AM
Thanks for this post, great job on showing how its done. This is on my "want" list of things and knowing now its not that bad to install moves it up the list!
HDRDH08 is offline
post #10 of 66 (permalink) Old 07-10-2012, 10:38 AM
good write up...been wondering about them.
2012 HD Road Glide Ultra
Willie G chrome accessories
RineHart exhaust
LA Choppers 18" apes
progressive front lowering springs
6" FBI windscreen----freaking useless
Scrape Made MagLite mount for apes
on the wish list:
Cyclent Cycles stretched bags and rear fender
painted inner fairing
Gabriel rear air shock with compressor
21" front
powdercoating:
most engine chrome and accessories
tour pack docking
LARGECARTRANSPORT is offline
Custom Dynamics LED Inserts - Install Question Chris529 Aftermarket Accessories 5 01-27-2016 11:08 PM
Keeps blowing turnsignal bulbs!!! Tim9339 Lighting 4 08-02-2013 08:40 AM
WTB or WTT - Rear turnsignal red lens NCRG12 Wanted! (Buy or Trade) 2 06-20-2013 08:08 PM
Led turnsignal fog lights. 11FLTRX103 Do-IT-Yourself 7 06-12-2012 06:09 PM
Turnsignal bar wiring diagram bvette94 Lighting 0 07-24-2011 11:41 AM
