Completed 3 Projects - Road Glide Forums
post #1 of 11 (permalink) Old 07-22-2012, 08:44 PM Thread Starter
cobra206's Avatar
This weekend i was able to complete a bunch of project i wanted to get done on my 2012 Road Glide Custom:
1. Add an additional 12v accessory port to my left glove box (thanks you to the members of the forums who have posted similar projects)
2. Add locks on my glove box doors.
3. Add an additional audio input to my stock Harley radio so i could use the XM feature on my Zumo 665 without have wires across my dash.
cobra206 is offline
post #2 of 11 (permalink) Old 07-23-2012, 04:49 PM Thread Starter
cobra206's Avatar
Project 1
Install additional 12v accessory port in left side glove box.
Parts Needed:
  • 12v adapter from Harley- Ebay $15
  • 16 gauge wire (stranded) red & black (bulk wire 25' each)- HomeDepot $10
  • dual male spade & female spade connectors - Radio Shack $5
  • Harley Davdison wire conduet- $3.50 from Dealer
After removing the fairing, I decided to place my new adapter in the left side glove box. I just so happens i have a habit of putting my phone and MP3 player in that box so it works for me. It also happens to be close to a power source so i don't have to add a bunch of wires all over the place.
I used a 7/8" spade bit to drill a hole in the left box. I used a hobby file to clean up any burs. And then just installed the adapter, simply place the adapter in the hole then screw the housing on from behind.
As for the wiring, i measured out how much wire i needed and added female spade connectors to one side, I am a little OCD so after crimping, i also soldered the connection. I then heat shrink'd the connections and added a slightly larger piece to cover the head (just to add that professional look). On the other end of the wires i used dual male spade connectors from radio shack so i didn't have to cut and tap the existing wiring.
Connected the female connector to the new adapter and the dual adapter to the existing 12v adapter, then connected the stock wiring to the second male adapter. tada all done.
cobra206 is offline
post #3 of 11 (permalink) Old 07-23-2012, 04:52 PM Thread Starter
cobra206's Avatar
The first set of pictures (above) show the inside of the glove box before the mod and after the mod. The second set of pictures (below) show a close up of the new adapter and an inside view...
cobra206 is offline
post #4 of 11 (permalink) Old 07-23-2012, 05:05 PM Thread Starter
cobra206's Avatar
Project 2.
Install locks on the glove box doors.
-Lock kit was provided by eGlideGoodies.com.
-I just followed the instruction included with the kit and installed with no problems. I would mention however that the instruction ask you to use the reinforcement ribs in the door lids to help measure out the location for the locks, however on the new road glide models the reinforcement ribs are only in the bend of the doors, they don't run the length of the door so a little more time and effort is needed to measure out your drilling locations... Everything you need to do the mode is included (even the drill bit). I opted for the the matching key set for a little extra money...
the mode came out great. no complaints.
I was thinking that in the future i might remove the self tapping screws (used to mount the lock bar) and use a screw and nut combo... but for now the self tapping screws are working just fine.
for pictures, take a look at my other thread.
Removal of Glove Box Doors
cobra206 is offline
post #5 of 11 (permalink) Old 07-23-2012, 05:41 PM Thread Starter
cobra206's Avatar
Project 3:
Adding a rear audio input to the HK Harley Radio.
I honestly just followed the blog found on Iron Aces Speed Shop's website. The instructions were clear and precise with great pictures... I will just try to sum up what i did.
If you want the instructions check out How To: Hardwire AUX input on Harley-Davidson stereo
After removing the radio, i removed the face plate ( IMO the hardest part of the the whole mod. I did the mod exactly like the "instructions" so i drilled a hole in the component plate (used a hobby file to remove any burs) and inserted a grommet (purchased from radio shack) into the hole. I brought a 3 foot audio extension wire, also from radio shack and cut it at 1.5".
After trimming the cable i threaded the cable in the hole to the front audio port. (as per instructions). Soldered the points and buttoned the whole thing up.
cobra206 is offline
post #6 of 11 (permalink) Old 07-23-2012, 05:43 PM Thread Starter
cobra206's Avatar
above pictures show the hole and grommet as well as the wire routing. The picture below show the wires soldered to the front audio input...
I had previously purchased and installed the Iron Aces mount for my zumo 665. It looks and functions great... very pleased...
cobra206 is offline
post #7 of 11 (permalink) Old 07-24-2012, 12:07 PM
Dhambrick's Avatar
Great projects! I am going to end up putting a power port inside one of the glove boxes as well.
'12 RGU in BBP
Stuff done, more to come
'10 FLHP in Birch White (RIP)
Dhambrick is offline
post #8 of 11 (permalink) Old 07-24-2012, 04:18 PM
great job on the projects...I love that power port.
2012 HD Road Glide Ultra
Willie G chrome accessories
RineHart exhaust
LA Choppers 18" apes
progressive front lowering springs
6" FBI windscreen----freaking useless
Scrape Made MagLite mount for apes
on the wish list:
Cyclent Cycles stretched bags and rear fender
painted inner fairing
Gabriel rear air shock with compressor
21" front
powdercoating:
most engine chrome and accessories
tour pack docking
LARGECARTRANSPORT is offline
post #9 of 11 (permalink) Old 07-25-2012, 07:51 PM Thread Starter
cobra206's Avatar
Thanks, the funny part is the hardest part of all three projects was getting the fairing back on...
Sent from my DROID2 GLOBAL using Motorcycle.com Free App
cobra206 is offline
post #10 of 11 (permalink) Old 08-27-2012, 10:15 PM
Q-Hog's Avatar
You installed some real functional mods. Looks great..
Q-Hog is offline
What other projects/hobbies eat your cash? Sincecrazy General Off-Topic Discussions 190 10-20-2017 11:57 AM
Back on the road... Winter projects completed toogood8p *General Road Glide Discussions/Pictures 8 03-10-2015 11:35 AM
Show us your other projects! redbeard719 General Off-Topic Discussions 3 02-14-2013 09:27 PM
Winter projects! Mopar1 Do-IT-Yourself 2 01-26-2012 12:50 PM
Winter Projects CustomGlide *General Road Glide Discussions/Pictures 42 10-21-2011 05:59 AM
