2012 RGU Exhaust - Road Glide Forums
post #1 of 13 (permalink) Old 07-30-2012, 05:02 PM Thread Starter
k9shag's Avatar
2012 RGU Exhaust
Anyone have instructions or a video link for removal of the complete exhaust system. I need to determine if this is something I want to tackle on my own or not. Don,t want to screw something up and have a hard time with my warranty.
Thanks
2012 RG Ultra
k9shag is offline
post #2 of 13 (permalink) Old 07-30-2012, 05:31 PM
Bad_Blue's Avatar
Exhaust is pretty easy, I don't think you need a manual or a video. There are brackets under the saddle bags, a couple of clamps that you need to loosen, and the the bolts holding the header pipes to the engine. And the 02 sensors that I believe just unplug and unscrew.
I know that doesn't help you much, but I'm replying because I didn't use to do a lot of work to my bike, I was worried, but it's a pretty simple machine as long as you don't tear into the engine. You should be able to do almost any project on your own, just pay attention to what came from where, and label if you have too. Exhaust is a pretty easy mod.
2012 FLTRX/Big Blue Pearl
Bad_Blue is offline
post #3 of 13 (permalink) Old 07-30-2012, 05:54 PM
staush's Avatar
Best advice-----get a manual. You'll need it to put together.
staush is offline
post #4 of 13 (permalink) Old 07-30-2012, 07:49 PM
remove bags,2 bolts for mufflers on the saddlebag brackets,clamp for each muffler.after muffler is unclamped,wiggle and pull till it comes off.
2 hose clamps on each of the 3 heat shields,unscrew to remove.clamp for pipe to left side under bike.remove sidecover,it just pulls off.unplug both oxygen sensors then cut tie-wraps holding wires to frame.remove 2 bolts at back of each cylinder holding pipe on.
remove pipes from the front first,then out of the rear.you may want to remove the floorboard on the right side if you do not have the extension on it.
assembly is the reverse of dis-assembly not a difficult job really, much simpler then it first appears.
danglide is offline
post #5 of 13 (permalink) Old 07-31-2012, 04:02 AM
Radioactive's Avatar
Before you unplug the O2 sensors, mark the front or rear sensor socket where they plug in and the cable so you don't get them reversed.
Radioactive is offline
post #6 of 13 (permalink) Old 07-31-2012, 08:52 AM
I went to do that on mine,they were already marked they actually have a raised "G" and "B".
danglide is offline
post #7 of 13 (permalink) Old 08-16-2012, 08:25 PM Thread Starter
k9shag's Avatar
Just received some Drago true duals from another member is there a trick to putting the true duals on I assume front pipe first but since I have no instructions not sure how to mount the crossover pipe under the frame.
thanks.
2012 RG Ultra
k9shag is offline
post #8 of 13 (permalink) Old 08-20-2012, 04:39 PM Thread Starter
k9shag's Avatar
bump for some advice
2012 RG Ultra
k9shag is offline
post #9 of 13 (permalink) Old 08-20-2012, 05:24 PM
put the back one in first,but not bolted,then the front.you may have to tug a bit to get the front worked into the hole.
not sure about the crossover,maybe it uses the stock clamp under the bike? the clamp goes over the pipe then onto a tab on the frame.
danglide is offline
post #10 of 13 (permalink) Old 08-20-2012, 05:25 PM
Ranger75's Avatar
Its pretty easy but explaining over this medium probably won't be alot of help. There should be a bracket / clamp that attaches the cross over (under) to the underside of your bike. If you contact Frank at Dragos, he might send you a printed installation guide. Look him up on this forum as he's a sponsor & a very helpful and knowledgeable fella.
Be polite, be professional, but have a plan to kill everyone you meet.
Ranger75 is offline
Thoughts? 15 RGU CVO vs 18 RGU??? RonC26 *General Road Glide Discussions/Pictures 37 05-11-2017 09:11 PM
2012 UC Wheels on a 2012 RGU Help 06SuperG Wheels and Tires 9 07-31-2013 03:52 PM
My new RGU vs my 08 RGU mhud3780 *General Road Glide Discussions/Pictures 28 03-02-2013 09:44 AM
Wanted stock 2011 or 2012 exhaust head pipe for RGU boomerman Classifieds Archive (3 months old+) 6 08-15-2011 08:26 AM
