Electrical Problems/Deutsch Connectors - Road Glide Forums
post #1 of 2 (permalink) Old 07-31-2012, 10:07 AM Thread Starter
mmcmsw's Avatar
Been reading on here for a year or so, and suddenly, the light went on. I used to work as the Final Test Engineer for an industrial Diesel Generator company. Wiring Harnesses were a pain. Here is the link to the tool I used to pull apart, and put those tricky suckers back together. Made my job easier.
The LADD DT/RT1. A screw driver with a little hook on one end.
http://www.electricalhub.com/deutsch...s-removal-tool
Trailers are for Boats!!
mmcmsw is offline
post #2 of 2 (permalink) Old 07-31-2012, 12:53 PM
HogWild's Avatar
Thanks Rob. May try one out. I've been using a hair pin with the little end pulled off. Works pretty good but a little to flexible at times. Is it too early for an annulment?
"No man is rich enough to buy back his past, so enjoy the moment"
HogWild is offline
Wanted: GASKET/SEAL that is used between the Fuel Injector electrical Connectors Wood Wanted! (Buy or Trade) 3 12-07-2017 09:22 PM
Best way to put Deutsch Connectors back together! 1BadGlide Controls & Handlebars 7 07-10-2013 08:50 PM
Sharing part # & pricing for waterproof electrical connectors Proud50 Do-IT-Yourself 5 05-28-2013 07:56 AM
2012 RGU electrical problems PghCycle 24 *General Road Glide Discussions/Pictures 6 06-11-2012 05:30 PM
2012 fltru electrical problems Top_P Troubleshooting for Road Glides 6 04-17-2012 09:53 AM
