Primary jam nut is jammed! - Road Glide Forums
post #1 of 8 (permalink) Old 08-04-2012, 02:17 PM Thread Starter
exammo's Avatar
I am trying to do my 10K service and can't get the jam nut to break free. It just spins the clutch pack when i start putting the pressure to it. I thought about trying to hold up the clutch pack with a screw driver or something. What do yall suggest?
Jeremy
I own a Road Glide!!!!!!!!!!!!!!!
exammo is offline
post #2 of 8 (permalink) Old 08-04-2012, 02:22 PM
Triplej's Avatar
Put her in gear and tie the ft brake up then give it a try.
Triplej is offline
post #3 of 8 (permalink) Old 08-04-2012, 02:38 PM
i used the round part of a T-handle between the chain and the sprocket,then give it an steady pull with a breaker bar,always worked for me,but you have to be careful not to break teeth on the gear.
I know it isn't by the book,but always worked for me
danglide is offline
post #4 of 8 (permalink) Old 08-04-2012, 02:43 PM
ZachB's Avatar
Are you holding the the threaded part with an allen key?
2015 RGS 103" Denim Black, Drago's 2:1, SE Heavy Breather, SEPST, Tuned. That will do for now.
ZachB is offline
post #5 of 8 (permalink) Old 08-04-2012, 04:31 PM Thread Starter
exammo's Avatar
I got it. I think they torqued the hell out of it on my 1 or 5k service.
Jeremy
exammo is offline
post #6 of 8 (permalink) Old 08-04-2012, 10:39 PM
staush's Avatar
You put a socket and ratchet on it and give it rap with a hammer. (the ratchet)
staush is offline
post #7 of 8 (permalink) Old 08-04-2012, 11:19 PM
skratch's Avatar
remember when you tighten it back, the torque spec is not very high. somewhere between 8 - 11 ft/lbs....
skratch is offline
post #8 of 8 (permalink) Old 08-05-2012, 05:45 AM
TheDoctor's Avatar
Just had this problem yesterday. Wouldn't break loose. Couldn't think of how I'd get it off without damaging things. 1 tap on the trigger of the impact gun took the nut completely off. Filed that 1 under things to remember.
2010 FLTRX
TheDoctor is offline
over jammed with anti-seize and more h-donut Wheels and Tires 20 03-18-2013 12:00 AM
Nut & bolt compartment shermanator *General Road Glide Discussions/Pictures 1 01-16-2011 03:33 PM
well nut solution ?? JacktheBagger Troubleshooting for Road Glides 9 08-03-2010 08:53 PM
Windshield nut fell back into shark nose? ToddTribe Troubleshooting for Road Glides 20 05-15-2010 07:27 AM
