50,000 Mile - Road Glide Forums
post #1 of 3 (permalink) Old 08-23-2012, 08:26 AM Thread Starter
scayne62's Avatar
50,000 Mile
Can anyone tell me what I need to do for a 50,000 mile check up, if anythign special? getting ready to turn it on the way home from work tonight and want to egt it done ebfore my trip to Bikes Blues and BBQ, I knwo I should have the manual and it is in the mail just want to egt a head start on it this weekend if there is anythign special I have to do. TIA
No better way to see the world than outta the cage and in the wind.
02 RG Luxury Rich Red
12" KW windshield
Bassani Exhaust
King Tour Pak
Stage 1
Sundowner Seat
Pretty shiney stuff
scayne62 is offline
post #2 of 3 (permalink) Old 08-23-2012, 09:40 AM
chromedome's Avatar
It's on page 1-9
https://www.roadglide.org/showthread....eferrerid=8741
but....
change all fluids, oil filter, spark plugs, disassemble & repack steering head bearings. inspect everything else.....
2012 Road Glide Ultra (SOLD) & 2015 BMW R1200RT
chromedome is offline
post #3 of 3 (permalink) Old 08-23-2012, 10:12 AM
DED HD's Avatar
This is the 50,000 mile service for a 2010 Road Glide-
Engine oil and filter
Replace
Oil lines and brake system
Inspect for leaks, contact or abrasion
Air cleaner
Inspect, service as required
Tires
Check pressure, inspect tread
Wheel spokes (if equipped)
Check torque
Primary chaincase lubricant
Replace
Clutch
Check adjustment
Drive belt and compensator sprocket
Inspect, adjust belt
Brake and clutch controls
Check and lubricate
Jiffy stand
Inspect and lubricate
Fuel lines and fittings
Fuel tank filter Replace
Brake fluid
Check levels and condition
Brake pads and discs
Inspect for wear
Spark plugs
Inspect
Electrical equipment and switches
Check operation
Front fork oil
Replace
Air suspension
Check pressure, operation and leakage
Windshield bushings (if applicable)
Inspect
Fuel door, Tour-Pak, saddlebags (if equipped)
Lubricate hinges and latches
Critical fasteners
Check tightness
Battery
Check battery and clean connections
Exhaust system
Inspect for leaks, cracks, and loose or missing fasteners or heat shields 3
Road test
Verify component and system functions
'10 Red Custom:
DED HD is offline
50,000 mile oil change gsbuick65 Fluids and Lubricants 13 03-02-2017 08:55 PM
Amsoil 20-50 syn vs Harley 20-50 syn mach65 *General Road Glide Discussions/Pictures 40 04-22-2015 07:41 PM
Just shy of 50,000 miles.... BigPoppi76 Engine Related 14 11-20-2013 05:19 AM
Mix of 15/50 and 20/50 M1 in crank OK? Emdog *General Road Glide Discussions/Pictures 19 07-29-2012 07:29 PM
Looking for Reliability - 50/50 Freeway/City Bigdaddy Engine Related 19 06-11-2012 04:08 PM
