20k Service & NGK Spark Plugs - Road Glide Forums
post #1 of 19 (permalink) Old 09-09-2012, 09:52 AM Thread Starter
jimmyray11349's Avatar
anybody use NGK spark plugs in their RG? Oreily sold me some NGK, DCPR7E for my 10RGC 96". I have 20k miles and stock plugs are Champion and still look good, runs good.
Going on a 1400 mi road trip in 2 weeks and wondering if I should change plugs out and if NGK acceptable.
since my post found this cross reference chart.
http://www.nightrider.com/biketech/hdsparkplugs01.htm
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
jimmyray11349 is offline
post #2 of 19 (permalink) Old 09-09-2012, 10:27 AM
Torquey's Avatar
I always replace my OEM plugs with the same every year. NGKs should be fine if they are in the appropriate heat range. The only negative comments I ever hear about plugs is about some of the fancier, more costly plugs like the E3 spark plugs. Some folks rave about the standard Autolite plugs.
Torquey is offline
post #3 of 19 (permalink) Old 09-09-2012, 10:47 AM
skratch's Avatar
i used to use the autolite 4164s in my bike. can't say that i ever had any problem with them, but when i bought my 2010, and was researching tuners, jamie at fuelmoto recommended staying with the stock plugs (and not the se) because of the spark knock sensor in our bikes. the ecm looks for a certain resistance value, and aftermarket plugs, may or may not, meet this value. so based on his recommendation, went with the powervision, and stock plugs.
skratch is offline
post #4 of 19 (permalink) Old 09-09-2012, 10:54 AM
tdkkart's Avatar
I run the NGK's in mine, no issues. I try not to run Champions(who makes the HD OEM plugs) in anything, had nothing but bad luck with Champions for years.
tdkkart is offline
post #5 of 19 (permalink) Old 08-07-2014, 03:01 PM
I have the se plugs in mine so......that must be why I get the pingin and the knockin even when accelerating at hwy speeds.
Jimbo58 is offline
post #6 of 19 (permalink) Old 08-07-2014, 03:30 PM
Brewiz's Avatar
NGK here too, just changed them out and they looked great....
Brewiz is offline
post #7 of 19 (permalink) Old 08-07-2014, 05:14 PM
tmd
OEM and Autolites seem to work great for many. Other plugs may give you pinging and knock issues due to the ion sensing. Some will even cause a check engine light to come on.
tmd is offline
post #8 of 19 (permalink) Old 08-07-2014, 05:49 PM
tdkkart's Avatar
I've seen more than 1 good engine builder/tuner recommend the NGK as not messing with the ion sensing. I normall run the DCPR8 plug, which is one heat range cooler. Cooler plug means less chance of the plug itself causing a pre-ignition issue.
tdkkart is offline
post #9 of 19 (permalink) Old 08-08-2014, 09:24 AM
mtloafer's Avatar
I bought and installed the NGK Iridium plugs last spring. I've had people say I shouldn't have, but I have had no issues at all. Any reasons I shouldn't have?
06 Road Glide FLTRI
I Always Gotta Be F*%$ing with Something!
mtloafer is offline
post #10 of 19 (permalink) Old 08-08-2014, 09:54 AM
Our old saying is the NGK stands for No Good Kind. That being said I have run them plenty of times without issue. Old mechanic joke.
HogPro is offline
Time fer my 20K service... Johnzz1420 *General Road Glide Discussions/Pictures 20 01-22-2014 08:34 PM
Spark Plugs-Knock Sensor BackRoads" Charlie Tech Area 2 01-13-2013 06:16 PM
Rusty Brown colored spark plugs ChivoChavez321 Troubleshooting for Road Glides 1 11-30-2012 06:43 PM
Spark Plugs? brhodea Do-IT-Yourself 3 07-19-2012 10:33 PM
Spark plugs ? Big Moke *General Road Glide Discussions/Pictures 9 06-03-2012 07:05 PM
