Installed a CVO Rear Fender on my 2011 RGU - Road Glide Forums
post #1 of 36 (permalink) Old 09-27-2012, 01:43 AM Thread Starter
sdlakerfan79's Avatar
Today I got my CVO rear fender back from the painters and tested out the wiring job I did. It worked!
I disassembled the male plug on the rear cvo wiring harness, clipped off the little metal leads (for some reason, they were the wrong type of lead/input), put new ones on, and plugged them into a male RGC/RGU 8 pin connector/plug I purchased from the stealership.
The only thing I'm kinda lost on, is where do I put the L and R wire harnesses that power the L and R LED lights (turn signals)? They have what looks like little black clips on them, but cant figure out if i put them under the rear fender, or just under the cvo fascia. Anyone got a clue?
sdlakerfan79 is offline
post #2 of 36 (permalink) Old 09-27-2012, 02:54 AM
RichieRich's Avatar
Can't help with the question but its looking really good so far!
2013 BBP FLTRX
RichieRich is offline
post #3 of 36 (permalink) Old 09-27-2012, 07:45 PM
Q-Hog's Avatar
Sorry I can't help. But I'm subscribing. I will be installing my CVO fender this weekend, so this thread should help me as well..
Q-Hog is offline
post #4 of 36 (permalink) Old 09-27-2012, 08:20 PM
FL99M3's Avatar
I installed the CVO rear end on my 2009 RG. If I understand the question right, just run the left and right rights down each side of the frame and the rails and then plug them in. Do not run them under the fender. You sort of break them out at the top. Man, I hope I explained this right and my apology that I didn't take pics.
FL99M3 is offline
post #5 of 36 (permalink) Old 09-27-2012, 08:39 PM
ThunderBueller's Avatar
The wiring for each side goes between the fender and strut and then follows along the bottom side of each strut. The same way your antenna wiring goes.
You can kind of see here where it goes. The wiring in the hole is for the LP light, the flat-six plug is for my Tour Pak.
Tom
2010 FLTRX--Primo paint set #83
2005 FXSTB--Sold. Gonna miss it!
2003 XL1200C--Sold
2002 Buell S3T Thunderbolt--Sold and much missed.
ThunderBueller is offline
post #6 of 36 (permalink) Old 09-28-2012, 12:21 AM
Thats exactly what i did as well. In fact i used FL99M3 bike as my inspiration to do the cvo conversion in the 1st place. I use black wire ties to secure each harness to the frame and you cant notice anything. Like others have said dont run them under the fender.
post #7 of 36 (permalink) Old 09-28-2012, 10:35 AM Thread Starter
thanks for the help. i finished the install last night. man, that fender was a pain in the arse to put in, that horseshoe type thing that the secures the fender to the saddlebag supports sucked. I had to remove it...I tried to install the fender leaving it on, but I just couldnt get the fender in the right location...so I had to remove that metal piece. once I got the fender properly aligned, i put the horseshoe type metal bracket back on. I think if I had a wider selection of tools it would have been easier. hey, you work with what you got. Anyways... all is well now. yeah, the harnesses that go to the Left and Right turn signal are on the outside of the rear fender stuts in a secure location. everything works like a charm!
peep!
Harleyhoots likes this.
post #8 of 36 (permalink) Old 09-28-2012, 01:38 PM
Q-Hog's Avatar
Looking sweet... Does the CVO light work in run, brake & turn? And if so, did it require any additional hardware besides what it came with?
Sent from my iPhone using MO Free
Q-Hog is offline
post #9 of 36 (permalink) Old 09-28-2012, 01:52 PM Thread Starter
yep. everything works perfectly. the only thing I needed to buy was the 8 pin male connector that my RGU wiring harness had on it, so i can plug into the 8 pin connector beneath the seat... and I bought 6 pins (i stripped the old pins off the cvo connector and replaced them with the onces that are designed for the rgu/rgc. thats it.
post #10 of 36 (permalink) Old 09-28-2012, 03:20 PM
RichieRich's Avatar
Looks damn good man. Good job. I know who will be helping with mine one day
2013 BBP FLTRX
2011 RGU Saddle Bags with lids and Rear Fender dgass38 Parts for Sale 2 12-20-2013 01:33 AM
2011 RGU Vivid Black Rear Fender powergod Parts for Sale 2 08-04-2013 06:16 AM
Canadian rear fender to U.S. rear CVO fender mikehall11 Lighting 10 06-05-2013 01:45 PM
CVO rear end parts for a 2011 RGU sdlakerfan79 Do-IT-Yourself 7 09-13-2012 08:37 AM
CVO rear fender assembly painted and installed Wheelie Paint & Bodywork Section 16 02-27-2012 10:42 PM
