Oil Change interval - Road Glide Forums
post #1 of 14 (permalink) Old 10-03-2012, 10:07 PM Thread Starter
Oil Change interval
I have always changed my oil at 3000 miles. I put synthetic oil in my RG on my last oil change. My question is do I still change 3000 miles? Thanks...
bfore is offline
post #2 of 14 (permalink) Old 10-03-2012, 10:57 PM
NorCal's Avatar
welcome to the forum, there are so many oil threads here your head will will spin... do a search and you will be amazed...
NorCal is offline
post #3 of 14 (permalink) Old 10-03-2012, 11:03 PM
I run Redline Syn. & do 5K
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #4 of 14 (permalink) Old 10-04-2012, 08:56 AM
JacktheBagger's Avatar
I have oil analysis done after every oil change and I have gone 7000 and still had plenty of "good stuff" left in the syn oil
JtB
2011 Ultra
JacktheBagger is online now
post #5 of 14 (permalink) Old 10-04-2012, 09:03 AM
Still Grumpy's Avatar
What if it takes a person more than 3 months to rack up 3,000 miles.
I think a better question would be :
"How many months should our engines go without an oil change; considering that it would have way under 3,000 miles."
Still Grumpy is offline
post #6 of 14 (permalink) Old 10-04-2012, 09:50 AM
laxinharley's Avatar
I typically change mine twice a year. I go by the service manuel which for me has been the 1000, and 5000 mile change but I usually will also change just the engine oil in the spring. Depending on the winters here in CT depends on if I do it or not. Last year I rode clear thru the winter so I did not change it early spring. I think if your in an area that gets super cold and your bike sits you should change it more often.
laxinharley is offline
post #7 of 14 (permalink) Old 10-04-2012, 10:05 AM
tmd
I've been going 5000 miles between changes on every harly I've owned and thats with both dino oil and syn oil. Unless your one of those riders that only puts a few hundred miles a year on your trailer queen then I would suggest changing it annually.
tmd is offline
post #8 of 14 (permalink) Old 10-04-2012, 10:13 AM
tdkkart's Avatar
Admittedly I'm one of the last holdouts on the 3000mi oil change, and I don't believe you can change your oil too often, however the days of 3000mi oil changes have gone by the way side. Unless you are in a situation where you ride less than 5-10 miles every time you start the bike, or ride in really adverse weather where your engine never gets fully warmed up, you will be fine with 5000mi changes, especially if you're using a quality synthetic oil.
I certainly don't agree with everything the MoCo puts out, but if they're willing too warrantee the engines with 5000mi oil changes, that's good enough for me.
('course there is the fact that very few riders will ever get past their 2nd oil change in 2 years)
tdkkart is offline
post #9 of 14 (permalink) Old 10-04-2012, 10:37 AM
DED HD's Avatar
I change the engine oil every 2500 miles, and the primary and tranny every 5,000. Amsoil
'10 Red Custom:
DED HD is offline
post #10 of 14 (permalink) Old 10-04-2012, 10:52 AM
qkshift's Avatar
I do 5000.00 use Royle purple and half qt. lucas syn.stabelizer like rp can see it on dipstick when new ride in winter when I can change inspring no matter how many miles
qkshift is offline
Oil Service interval vs Primary and Trans Problems calgaryglide Fluids and Lubricants 33 05-12-2018 10:48 AM
Fluid change interval Tim Powell Fluids and Lubricants 17 07-19-2014 11:45 AM
Service Interval print checklists Scootin Do-IT-Yourself 7 08-25-2013 11:19 AM
Clutch Adjustment Interval jimmyray11349 Controls & Handlebars 5 01-26-2013 10:44 AM
What to do with oil change oil? TearlessTom *General Road Glide Discussions/Pictures 15 11-22-2011 08:16 PM
